Engine ERROR Code P0100 AND P0110 Can anyone help?
Discussion in 'Powertrain' started by CorollaS916, Apr 26, 2004.
    CorollaS916 Guest
    I just checked my error codes through a handy little device my neighbor has and it came up with 3 error codes. they are
    P0100 MAF or VAF Circuit Malfunction
    P0110 Intake Air Temp Circuit Malfunction
    P0101 MAF or VAF CKT Range/Perf <-this one showed up under PENDING CODES
    Im not a really car techy guy, the first one I am guessing is b/c of my MAF not working anymore? The second and third one Im not really sure on...can anyone assist...thanks
    limp_noodle Guest
    how many miles on your car and what mods you have to the engine?
    CorollaS916 Guest
    around 20,000 miles and just a CAI...I found out that my MAF sensor needs to be replaced, it was mishandled during install which caused it to not read correctly the air flow. Also sorry to be off topic, but I found out that ALLDATA, a company that holds records and works with Autozone and Kragen and all them in vehicle diagnostics, they can hack into the ECU and change everything from shitf points to rev limiters to fuel/air ratio to anything else that is programmed into the ECU, and provide you with the necessary programs after they're done initially for any further changes you wanna make yourself. Im heading in there tomorrow to inquire...Not sure if anyone knew that or not.
