Engine engine swap
Discussion in 'Powertrain' started by newaki, May 26, 2004.
    newaki Guest
    engine swap
    I need some help guys.... in the next couple of months i will be hopefully tryin to get an engine swap done....
    i have a 92 base, i want get either a 4age or 4agez...
    but i need to know what i have to exactly get for this swap....?
    Thanks
    BLADDER_MASTER Active Member
    FL
    Mainly engine, tranny, and ecu.
    Corolla DX-R AE100
    Vancouver, B.C.
    02RSX Guest
    http://www.jarcoinc.com/inventory/
    tehy've got a couple gze's and 20V at good prices, and they include everything u need. I've only heard good things about them. they also have 6spd black tops
    newaki Guest
    i know the specs for the 4age engine. but ne1 kno the specs like horse power and torque for the 4agze?
    Thanks again guys
    02RSX Guest
    97ae102 New Member
    Mm.. I've read on the old forums that people who did the swap had problems obtaining the rated horsepower when they dyno after the swap. You might want to look into that as well.
    Pantaloon007 Guest
    also heard that- people getting 110 to the wheels. Thats alot more that 15%...
    toyotaspeed90 New Member
    Bellingham, WA
    i'm sorry to say... but getting the rated numbers from a 20V is HARDER than getting them from a 16V or a gze....
    if you're going for a 4a-ge 16v.... all you'll really need is someone who can modify the ecu for you.... the longblock, someone who can wire in the dizzy and aftermarket ignition, and new hoses..... seems most these people above haven't done it before :)
    for a gze... you'd be smarter to go with either a stand alone setup (ie, megasquirt) or find a gze ecu.... for that, you should try and find the complete harness as well to make things almost simple....
    for a 20V.... i'm not gonna get into it.... things for it are hard to find and if you don't have all the necessary parts / part numbers then i wouldn't do it....
    your stock tranny WILL work with any of these motors..... if you went with a gze you might wanna rethink it because you'll be getting near it's limit.....
    take it from someone who has an ae92 and has done a 4age swap.....
    Concordmk1 Guest
    Do the 20 valve.
