Engine Engine Pics With New SRI
Discussion in 'Powertrain' started by t0rres16, Jan 12, 2008.
    t0rres16 Member
    Yardley, PA
    I installed the sri the other day and here r the pictures
    Looks good, but you want to consider a custom cold air later on. Looking at your setup makes me think of all that heat soak.
    Dreadon Guest
    ebay special i assume i bought the same thing only with a blue filter also how were u able to get it so high i didnt put mine like that i dropped it as low as i could to get keep the engine heat away from the filter and also mine would hit the brake cylinder and would rattle my brakes when i pressed them
    My very first ebay SAI was exactly the same. It rattled and actually lost me power to the point where I went back to stock. It was an experience though.
    t0rres16 Member
    Yardley, PA
    my brakes rattle i was wondering why they did that; now i know thanx
    I noticed a gain in acceleration, but the main reason i bought it was for the sound because i knew a 10 dollar intake wasn't gonna give the car a lot a power
    t0rres16 Member
    Yardley, PA
    i did but i only noticed a little sound difference thats why i bought this intake
    94 rolla Guest
    run no filter :D
    If you plan on keeping this intake, maybe you should heat wrap the tube and get a heat shield for the filter.
    jeprox Active Member
    you didnt get any CEL?
    if you change your exhaust + your intake, you can gain a tiny bit of horses. with the intake, you gain low end torque so it feels faster off the line... but you loose some at top end.
    i miss my 03. :(
    t0rres16 Member
    Yardley, PA
    i changed the position of my intake and now my brakes dont vibrate anymore
    t0rres16 Member
    Yardley, PA
    am gonna make a custom CAI with this one soon
    rolla996 Guest
    lol don't laugh at me but.....
    I would really like to know what it sounds like? can u show a vid or something. Searched youtube, nothin much on 8th gens
    <a href="http://vvti.net/forums/showthread.php?t=14393" target="_blank">http://vvti.net/forums/showthread.php?t=14393</a><br />
    Search the forums next time or try different key words.
    someone explained it to me when i bought mine and it makes sense.
    sri will improve throttle response and a little bit of high-end power
    cai will also improve your throttle response but not as much, and will add more power than the SRI
    yours looks a little bigger then mine for some reason.
    http://a549.ac-images.myspacecdn.co...f09c7b4022c.jpg
    Dreadon Guest
    thats cause its an ebay special it is longer almost identical to the injen one but it doesnt have the brakcets to bolt it down to which is stupid and the filter is huge i want to change it out
    las vegas
    too me any sri or cai perform the same way and give the same gain but its up to if you want to buy top brand(aem or injen)also i never did see anybody post a dyno with different variety intake(sri &amp;cai).
    las vegas
    oh torres16 i like how you polished you intake manifold well nice and clean,i did the same when i had my rolla.
    What you need is a custom 2 stage variable intake. A Short Cold Air Variable Intake(SCAVI) I call it. It would have 1 long traditional tube just like a CAI running into the fender with a filter. A 2nd tube would branch from the long tube close the the throttle body and end with a filter still under the hood(SAI...short air intake). A butterfly valve would be covering the junction to the short air intake side and rigged to open according to engine speed and load. The valve will remain shut at low engine speed and would open at high engine speeds, thus giving you the best of both worlds. Instant throttle response and torque from the CAI section and horsepower and flow from the SAI section. :D
    lol i wanna see u make that.
    Dreadon Guest
    that is kinda like the one from weapon R it is a short ram but it also has a coil thing going into the fender but it is missing this valve u can turn off
    the system weapon r has is basically 2 tubes in one making some of the air flow faster kinda like a jet engine. it doesnt have 2 valves its just 1 tube inside of the other to flow air a little faster
    as seen in this picture(i suck at hotlinking images)
    http://www.wesellcarparts.com/store...ecretweapon.jpg
    so as you can see, its not like the bmw one which has a sai attached to a cai. the attachment tube that comes with it doesnt count bcuz it doesnt cover the entire filter only the end of it and doesnt open or close at certain speeds so as rollatuner said you would have to make your own and program a valve to open and close at certian speeds, btw weapon-r did make a CAI for the 98 corolla if im not mistaken.
    is that the one someone bought for 70 bucks that was supposed to be used on boats and not cars?
