Engine engine light?
Discussion in 'Powertrain' started by jpbartosch, Jun 24, 2004.
    jpbartosch Guest
    It's actually PCV valve. It's about $8 at Toyota. I don't think there's a universal piece for this. Easy to change, I did it about a month ago.
    Charcol filter???
    killer2239 Lift at 5700rpm
    Lexington, KY
    Yeah, the 98+ VVTi and all i dont think have it. its a lil black can in the car, weights like 10 pounds it seems, haha. I would change PCV valve first, you can either go to a quick lube place such a Valvoline one, and there are like 10 dollars. Or go to toyota and get them for 8$ like jpbartosch said. its just a pop out and pop in thing like. Then if you still have problem, do the filter thing. I dont recall me ever having problem with mine, and i have 120thousand miles on my car.
    cworkm Guest
    Yeah he said there is a charcol filter that filters the fewms at some point in the gas line. I cant remember.
    cworkm Guest
    Yeah I never had any problem with my 95 corolla. Best car I ever owned. after a 120k miles the alternator went out but thats it. I killed it in a car accident at 185k miles though. RIP 95, I miss you. :(
    Thanks for the help guys, i will try changing that out first. where is it located?
    Lexington, KY
    Its just a small piece that plugs into a rubber hose that plugs into engine or part around it. I forget exactly, i changed mine with my dad a while ago. Its best to change them at least 1 time a year i think they say.
    d_samurai Guest
    a child could do the pcv valve easliy...its a piece of cake... look at red arrow-(93-97 engines only-98-02 has it on the right side of the engine) [IMG]
    as far as the charcoal filter-its right under the intake-there's a couple of bolts holding it down-a couple of silicon hoses going into them-and thats about it-its very easy-the question is trying to find it-i would go to your local dealership..
    d_samurai Guest
    oh yeah-while your at it-get some carberator/choke cleaner from any auto store-and spray that stuff INTO the pcv valve while the engine is running-itll suck it up and will spit it out the exhaust...-its also a good idea to take off the intake and clean the throttle body by spraying that stuff into it while the car's on and revvin too..
    cworkm Guest
    engine light?
    All right i took my corolla in for the engine light about 5 months ago and they told me it was because my "pvc valve and charcol filter were bad" I dont know if that is the correct names for the parts but thats my question.
    whats the right name or part number for those?
    Where can i get these parts cheap?
    How hard are they to do yourself?
    :confused: :confused: :confused:
