Engine engine flood
Discussion in 'Powertrain' started by curlupanddie420, Apr 15, 2007.
    curlupanddie420 Guest
    damn. I went through another puddle. It was too dark to see. Idk about you guys but NJ bergen county nj is flooded. Now it won't start. I had to leave it and get picked up.
    engine flood
    Hey I drove through a deep puddle and then my car turned off. It wouldn't start until about 15 minutes later. It wasn't performing right either. Does anyone know what happened? Do I have to get anything fixed? It is performing back to normal gradually. I'll have to wait and find out tomorrow morning. Any tips?
    leave the car alone for awhile - you probably got water in it, which is something that can kill your motor. i'd suggest pulling out the plugs/injectors, as well.
    SleepinRolla Member
    Socal
    pull out your dips tick and see if you have water in oil.
    daniel2002p Guest
    open the hood... take out the plugs... close the garage... and run a air drying machine (no idea what they are called) overnight and it should be good to go
    D
    Hydrolock sucks.
    stop driving through puddles and you wouldn't have this problem. if you see standing water, turn around and go elsewhere. there's a damned good chance you've completely borked your motor if you've driven through too many deep puddles and the car won't start.
    jtweezy New Member
    Irving, TX
    damn messed up a toyota :( its a crime!
    why? it's just a car...and common sense would tell a person to avoid deep puddles.
    How deep are these puddles? You know that rain guards are there for a reason.
    daniel2002p Guest
    Do you have a CAI???
    D
    i've researched and even took apart my dad's corolla to see where water could be leaking or getting in.. I have absolutely no idea why the car may be getting water inside.
    nah no cold air intake. I went back to my car this morning and it wouldn't start
    The stock air intake is on the drivers side above the fender. How is water getting all the way up there? Those have to be some monster aquarium-size puddles.
    i have a short ram that goes down. It's pretty low and my car is dropped and the puddle was about a foot deep. I"m going to do an oil/filter change, seafoam, and heet the gas tank
    cgreen38 Common sense, p
    Baton Rouge, LA
    You're most likely just hydrolocked, AKA screwed.
    You're going to have to tear the whole motor down and repair it or buy a new motor. Yes, you are screwed.
    DjiNN New Member
    well thats a good excuse to buy a new car or new motor ..
    DjiNN New Member
    thats Mother Nature for you .. She is such a bitch ..
    um, mother nature didn't make him drive through puddles. i realize that NJ has this "no left turn" problem, but still, he could have gone around them. :)
    not like he'd have a choice in the matter. if he wants a car that WORKS properly, he's stuck with one of two expensive choices.
    DjiNN New Member
    well buying a motor would be the LEAST expensive of the 2
    that doesn't make it inexpensive. ;)
    yes I am screwed. My motor blew up. Pieces of metal on the floor and oil leaking out. =0(
    figured as much. don't drive through puddles anymore. sucks you had to learn the hard way.
    Although I admit it is fun to hit puddles hard to wash out the people on the sidewalks. haha I've been soaked to the bone before. It's cruel but hey it happens.
    DjiNN New Member
    yea me too happened to me .. man it sucked
    yeahhhhh that's pretty mean.
