Engine Energy Suspension Motor Mount
Discussion in 'Powertrain' started by Barnacules, Aug 2, 2005.
    Barnacules 100101101011011
    Duvall, WA
    SD_S New Member
    SF, CA
    i want to know too
    Cape Coral, FLorida
    be the guinea pig
    teevee247 Well-Known Member
    Montreal, QC
    Well, according to Energy Suspension's website, they only make bushings for the 03-04 Corolla's, and only front control arm bushings... but I won't stop you from trying :)
    http://www.energysuspension.com/pages/toy.html
    They do have one listed for the 03 Matrix though,
    2003 Motor Mount Insert Set (front and rear torque positions, manual transmission only) 8.1101
    So now, just have to find out if the Matrix has identical mounts to the Corolla...
    01rollas New Member
    do what i did, and mount the engine directly to the frame.i did this but do not recommend unless used for moderate,to race applications only.
    Vamp Gunmetal 2001 Corolla S
    Rosedale, MD
    Gunmetal Grey 2001 Corolla S
    I'm filling in my engine mounts with polyurethane from the hardware store. It's a trick that people have done when they can't find inserts or are too cheap to pay for them.
    01rollas New Member
    I did that same thing and i managed to mess them up pretty bad.
    Rosedale, MD
    How did you mess them up?
    My motor mounts went bad and I need replacements fairly quickly. The motor shakes so badly, that it broke my flex pipe and now it's leaking. This is also the reason why the flex pipe is vibrating against my front sway bar. :( I've contacted Speed-Source to see if they could make a custom set. However, I'm also considering filling my motor mounts with polyurethane from the hardware store as well. I've read up on this a lot and I would do it, but it seems like they don't last very long.
