Emergency Brake Question
Discussion in 'Stop, Drop & Roll' started by MacktasticSlick, Mar 8, 2010.
    Does anyone know how to tighten the parking brake? I've noticed that I have to pull the handle up a lot higher now to make the car stay in place compared to about a year ago. I know it can be done, but I don't know if it's something that is easy to do with one person, or if I need special tools or whatever.
    SaberJ2X Lurk MOAR
    Mayawest, PR
    mine don't even work LOL... a DIY on how to replace the whole thing would be nice...
    they don't work since I was rear ended (car was parked)
    nyrican52884 Active Member
    Plymouth, MA
    Its easy. Remove the center console by removing a couple oc bolts in the storage and a couple of screws on the side where the shifter is. Then you will see one bolt that sticks up with 2 nuts on it. Loosen the top nut and then tighten the bottom one. Tighten the top one to lock it in place. Installation is the reverse of removal
    Ok I wasn't sure if it was something that is done under the car or something. I'll go take it apart now and see what I got. Thanks. I know how to take the console off already so that shouldn't be a problem. I've done this to my car in the past lol:
    your car has a brake that you use in case of emergencies?
    When dipshits cut me off, I actually do use it, so yes I suppose so. Although I keep the button depressed that way I can put it back down quickly in case the rear wheels lock up.
    Plymouth, MA
    The bolt I'm talking ab out should be to the left of the E-brake in the 1st pic you posted
    Yeah I already got it, worked exactly like you said. Thank you good sir. :D
    How is that a fail if I have never taken the car apart before? You can't do that in all cars.
    Because, just like on TN, most questions can be answered by simply just getting out there and figuring it out. Just sayin. It builds character.
    Well that was before I did anything of value to my car, and ir's not like I was saying I tried it and it was impossible, and I did search on here, I wasn't on TN when I posted this.
