Engine ECU question
Discussion in 'Powertrain' started by corolla_racer, May 5, 2004.
    corolla_racer Guest
    ECU question
    Can u use a 4afe ecu to run a 7afe????
    blancokracker Guest
    I don't think manual trannies have seperate ecu's, only autos do.
    cleanrolla97dx Guest
    3 speed auto tranny ecu same as 5spd stick ecu
    if you have an A/t w/ overdrive then you need the ecu from a stick or 3speed auto
    Def98rolla Guest
    DAMN OVERDRIVE :( how much would the ecu run me for?
    blancokracker Guest
    I still see no reason for a manual to have an ecu
    Def98rolla Guest
    neither do I but toyota did.....those bastards making it hard for conversions :(
    toyotaspeed90 New Member
    Bellingham, WA
    yes... in short.... there might be some emissions differences depending on years.....
    Def98rolla Guest
    finally got vvti back up :) okay since were asking about ecus I might as well....how much would the ecu of a mannny 1998 corolla run me? Im going to be doing the conversion cause auto well lets be honest sucks when it comes down to racing :( and for future mods itll help out alot.
    Lekz Guest
    fuel maps n shit
    i see ecus run for 150-200. www.car-part.com
    where are u getting the shift linkage and pedal assembly?
    Bellingham, WA
    even if it's electronically controlled, you can use the auto ecu with the manual..... but i would suggest that when you run by one, you grab a manual ecu.... watch your junkyards
    Pantaloon007 Guest
    The 4spd ECU is different from the 3spd and Man. The reason is that the 3spd is not elec. controlled. Niether(of course) is the man. You can get a junkyard ECU for about $50 from carparts.com- they linl to about 5000 junkyards across the country...
    Def98rolla Guest
    its aight I got a price for the whole conversion...1700 including labor so fuck it Imma go with that :)
