Engine Ebay short shifter for 95.
Discussion in 'Powertrain' started by killer2239, Aug 10, 2004.
    killer2239 Lift at 5700rpm
    Lexington, KY
    Thanks all. i just wish i knew that the 98-02 ones worked with my 95 for sure, cause i dont want to pay 100-200 for it and it not work.
    no, stay away that's total total bullshit.
    i'm pretty sure the 98-02 shifters fit in 93-97 corollas.
    twm makes a good one, B&M make a good one as well.
    Yea James is right.. I'm not 100% sure but I believe they are the same.
    But with the cheap ebay short shifters, people said they are complete crap cause all they seem to do is move 1st gear to where 3rd was and so on.. and in 5th you'd be hitting ur passenger's leg.. which isnt so bad depending on whos ur passenger.
    Lexington, KY
    So are those cheap 15 dollar short shifters worth it? Iv asked this before, but iv got some money to get it. I couldnt install myself, but i know company that could. I know it isnt the whole piece, so you gotta pop out the one in there, and put this one in. But is it worth it, cause no company makes a short shifter for a 93-97.
    jpbartosch Guest
    I have the TRD quickshifter. Good stuff. A short shifter with an aluminum flywheel makes some decent acceleration. Save your money and do it right. I've heard those garbage shifters on Ebay break. That's danger while driving.
    call twm and talk to them about it.
    they will send you a 98-02 one and if it doesn't work just send it back. i'm 95% positive it will work fine though. there may be slight differences but i dont think that it will matter whatsoever. for example the shifter for corollas is advertised 98-01, but i bought it for my 02 and there was a slight difference (there was no plastic cap on the ball joint of the TWM shifter, but there was on my stock shifter (or vice-versa) but i manned up and put that bitch in there and it's worked fine for over a year now.
