Easy Dent Removal
Discussion in 'Videos' started by TurismoDreamin, Apr 24, 2007.
    Tulsa, Ok
    Easy Dent Removal
    Items needed
    -Hair Dryer
    -Airduster in an aerosol can.
    -Clean cloth
    Follow the steps in the video:
    does this really work? i'm about to try that this weekend
    ??? I'm tempted but I doubt it would work. I have some dents that are on the door where its not then sheet metal like that which can pop right back.
    There's always this too:
    yeah mine is on the door too...doubt it would work
    brb trying this out
    you have rust on yours too lol
    =[ dont rub it in
    DOT. Noypi ako!
    Hmmm... I also have a dent on my fender.How much does a shop charge for a PDR job?
    Tulsa, Ok
    ^^I would imagine not that much since they'll only be doing it for an hour...at the very most..
    Similar techniques will only work if the dent is fresh - given enough time, the metal will take a "set", so to speak, and be more difficult to pop up. Also will not work for dents have a sharp creases or groove in the metal (metal deformation) - only for simple dents over a relative large area.
    They do make something called a Dent Wizard - basically a pad that gets attached to the middle of the dent with some epoxy, a bar than spans the damaged area, a "puller" that is attached to the pad and levers the dent out. Once you pulled the dent, you cut the pad off, clean up the residue and are good to go. Usually doesn't even need a repainting, because you didn't cause any damage. But same deal - doesn't work where there is significant metal deformation - just have to take it to body shop.
