DVD eject
Discussion in 'Interior' started by slvr2000fdvspec, 2004年07月03日.
    slvr2000fdvspec Guest
    super flat flathead screw driver..
    Concordmk1 Guest
    I've used my fingernail, I've used tiny flat head screwdrivers, and I even had success with a stright pin before. But the straight pin took forever. Test it again after you have the disc removed before putting anything else in. If it works, put in a disc you don't care about. Test again. If it doesn't work, remove it, otherwise you should be ok.
    rudalicious Guest
    cool thanks guys... chances are i wont be watching movies while im driving too much anyway :D
    rudalicious Guest
    DVD eject
    hey guys... I have an audiobahn avdvd1t which i dont think they sell anymore. well i was wondering if anyone knows where the emergency eject button is. for some reason mine wont eject the disc.
    thanks
    rudy
    theproof Guest
    use a hammer
    rudalicious Guest
    see thats what i was first thinking... but then i thought about it and slowly decided to think of a better solution.
    flathead and force that sucker lol
    Concordmk1 Guest
    pry it. Emergency eject? Never heard of one. I've pried them before and they've worked after, though every once in a while they won't.
    rudalicious Guest
    what did u use to pry it out? I tried some needle nose ... but i need smaller ones... either that or well i dunno what did you use?
    whitekorolla02 Guest
    He's right.
    rudalicious Guest
    well i tried the hammer idea and now i have my dvd back :)
    with most cd players there usually is a tiny pin hole where you can stick a small pin or end of a paper clip in to manually eject the disc.
