Engine DUDES FOUND A TURBO FOR OUR ENGINE!!!!!
Discussion in 'Powertrain' started by HONDO ROLLER, May 10, 2004.
    HONDO ROLLER Guest
    I COULDNT BELIEVE IT WHEN I SAW IT BUT GUYS HERES A WEBSITE THATS GIVING US GUARANTEED PARTS AND AT A REASONABLE PRICE. CHECK IT OUT THEY GGIVE 6 PSI OF BOOST AND A 30% OR 56% HP OF ENGINE HP HERES THE WEBSITE I BOU
    ONE RIGHT AWAY
    http://www.turbo-kits.com/corolla_turbo_kits.htmlGHT
    Misery Guest
    this isn't new .. its been around for quite some time now ...
    polo708 New Member
    9thgencorolla.com
    QUITE some time, sorry. There is also a SF kit that has been out for a while.
    polo708 New Member
    9thgencorolla.com
    go for the ballbearing upgrade, u wont be sorry
    HONDO ROLLER Guest
    any of you have this turbo kit on your rolla?
    Left-Track Guest
    Is it true that this turbo kit is safe on stock engine ?
    RexPelagi VDub
    Canton, Ohio.
    the t25 is meant for this general type of engine, originally designed for NA. It should be ok as long as its not boosted too much.
    tom Guest
    I wonder if you can combine the supercharger and turbo together. It seems like the supercharger works off the intake, while the turbo works by using the car's exhaust. If you combine them, wouldn't that make a tremendous amount of power? If your engine and tranny can handle it.
    Tro1086 Guest
    tom, it would be kinda pointless.
    First of all they are both made to force air into your engine.
    Second, a super charger dose not work off of your intake, that is imposible. You must have energy to make energy. A super charger is driven by a pully that is connected to your engine, so your engine is powering the super charger, not your intake.
    So having two things drawing power from your engine just to force air into it dosnt really make sense. Especially when you can just get one of them that is real efficient and forces lots of air with minimal power drain.
    tom Guest
    Hmm, I just thought turbo works off the car's exhaust right? Does it recyle it and use it like an intake then (to force more air)? The reason why I thought the supercharger was working off part of the intake is that, on my car, they replaced the entire stock intake manifold with the supercharger. So you can see where the air intake comes in through the pipe, into the throttle body, and goes to the supercharger where it compresses it and does all its good stuff. I thought the crank just helps power the supercharger, that's it. Just like how the exhaust powers the turbo.
    crovax New Member
    only real benefit of doing that would be low end power of the blower, then the turbo would spool really quickly to provide high end intercooled boost...but it wouldnt make any sense to do it unless you run lots of boost...and then still it wouldnt make sense to do it :)
    downey180 Guest
    if there was a way to have to seperate ways to get air into the intake mani, then i suppose it could work. like a split port type of thing. but would probably more trouble than would ever be worth.
