Engine Dual VVT-i
Discussion in 'Powertrain' started by DjFrOsT, May 6, 2005.
    DjFrOsT New Member
    Los Angeles
    Dual VVT-i
    WHAT??...read this...
    http://en.wikipedia.org/wiki/VVT-i
    towards the bottom...what does that mean? is the engine twice as powerful? twice as fuel efficient? two times better?
    anyone heard of this?
    toyotaspeed90 New Member
    Bellingham, WA
    it just simply means that the change in timing of the intake and exhaust cams will be seperate, rather than both cams changing together
    Dual vvt-i is not really new. Toyota used it on the newest BEAM 3S engine in Japan already. And now in the new Avalon too. :)
    teevee247 Well-Known Member
    Montreal, QC
    It may not be new, but I still want it! :D
    BangRolla New Member
    houston, texas
    i got dvvti yo.
    it makes 2000hp.
    jay dee emm
    Denver Rolla 98 impreza
    its also what they ar putting in the newer V6 Tundras...
    Laz Z Kay "n00B, be kind"
    Biloxi, MS
    Isnt that in the IS300 already??
    killer2239 Lift at 5700rpm
    Lexington, KY
    Its going into the new Camry for 06. And its going into 1 or 2 others that use V6's.
    7MGTTEConcept MK3 #2? maybe..
    Arvada, Colorado
    the dual part means that it's going to be on two heads instead of just the one. they'll both most likely kick in at the exact same time, just need two units to run it on a v6...
    edit - vvt-i may be in the is300...but it's not the dual vvt-i since the is300's run off a 2jz-ge non turbo straight 6 motor...
    Cuztomrollaz98 MAD VLAD!
    Littleton, CO.
    hmmm interesting :D damn I want one lol
    No, no our 2JZ-GE IS300 but 3S-GE Altezza in japan.
    DjFrOsT New Member
    Los Angeles
    "so how much would it cost me to swap my vvt-i to dual vvt-i"
    -RiCeBoY
    :D
    BLADDER_MASTER Active Member
    FL
    Wrong. If that were the case, you would see all the V6's with VVT-i called Dual VVT-i, but they're not. Unless of course the V6's that are out now only have VVT-i on 1 intake cam on 1 head based on your terminology. Dual VVT-i means that it has VVT-i on both intake and exhaust cams, 'nuff said. How Toyota manages to control it on a V6 setup I don't know.
    IS300 = 2JZ-GE = VVT-i
    corollarider19 New Member
    the new avalon is a beast
    FL
    Forgot that the new GS300 has Dual VVT-i as well.
    zze130 New Member
    Texas
    new IS will have dual vvti but toyota plans to put it in all cars
    Arvada, Colorado
    2 solenoids = dual solenoids (one solenoid per cylinder head)
    2 exhaust headers with non-intersecting pipes = dual exhaust
    just a theory :D
