Dual Halo Headlights
Discussion in 'Exterior' started by flavious27, Jul 28, 2004.
    flavious27 Guest
    I got my dual halo angel headlights in, I have them installed, but I need to know how to wire the angel lights and the little light on the inside tips (and what is that light for anyway)?
    noservice2001 Guest
    Re: Dual Halo Headlights
    did you read any of my previos posts? anyway... oxymoron is a real help... what did you need? did the halos work already? the city lights (little light on the inside tips) are for asian cars... equivalent to our DRLs i guess... so you could just have fun with those and hook them up to you signals lights... or add some storbe relay.... or something like that.... the halos are usually wired to the parking/signal bulbs... green and white... not the green with stripe...
    flavious27 Guest
    Hey, I the halo work, but I need to get the angel eyes wired up, so I need to know how to tap into the wires for the low beams. I also need to know how to tap into the high beams for the "city" lights, and I wonder what bulbs they are, because I may want to have blueish bulbs in them.
    noservice2001 Guest
    thanks to oxymoron i believe....
    There should be three wires going to the parking/signal lights:
    (1) - White with a Black stripe,
    (2) - Green, and
    (3) - Green with a Black stripe (driver side) or Green with a Yellow stripe (passenger side)
    Wire (1) is connected to ground. Wire (2) will have 12 volts on it when the parking lights are on. Wire (3) will have 12 volts on it when the signal lights are on.
    I don't know anything about your halos, but usually black is ground and red is power, so connect the black wire to wire (1) and connect the red wire to wire (2). I'm assuming you want the halos on when the parking lights are on.
    And for high beams... you might have to ask oxymoron for the wiring unless it's just black and white... did this even help at all?
