DRL's
Discussion in 'Exterior' started by KrypticKarma, Jan 20, 2008.
    KrypticKarma ~2001 Corrizm~
    Oshkosh WI
    DRL's
    Just a question about the daytime running lights. If I were to disable them.. would that also disable my automatic lights that turn on when it gets dark?
    Thanks
    DRL's are one and the same. They won't turn on at all if you disable them. You don't need them anyways. Just turn the lights on manually like people used to do before car manufacturers made them lazy. :D
    will this work on 01+ corolla? same method?
    JordanInc ZZE110
    im not sure...but my guess is yes
    JordanInc ZZE110
    just do it manually...its a good habit if you think about it.
    rolla996 Guest
    How can u turn off DRLs? i can't turn mine off at all. They always run and turn on brighter at night or tunnels. I don't mind, bur i'd like to be able to turn them off.
    I've noticed that the only time they stay off is when u start u'r engine with the handbrake on. Once u release it though it comes back on.
    Use the search button. It's been answered already.
    JordanInc ZZE110
    rolla996 Guest
    Wow Thanks bro. Thats easy as hell.
    DOT. Noypi ako!
    rolla02 Corollalcholic
    Delaware
    If you pull the fuse you will lose the DRL's and auto lights.
    JordanInc ZZE110
    ya i believe for 9th gens, its under the drivers side
    jhavens Guest
    Yes, the 9thgens is under the driver side. Just reach under the steering(above the pedals) and find the relay and cut one wire(don't remember the exact one), and then no more DRL's. It's just very awkward position to reach underneath the steering wheel.
