DRL shut-off
Discussion in 'Interior' started by Vibe, Aug 21, 2006.
    DRL shut-off
    I followed the DRL DIY from Vamp and cut the red/blue wire on pin #23.
    The DRL no longer works which is great; however, I now have a new problem.
    My gauge lights aren't turning on anymore. Has anyone had the same experience?
    Des Plaines, IL
    Quick question as its related to the subject. If I shut off my DRL will I still get auto on function when it gets dark? Anyway to make the auto on work?
    rolla02 Corollalcholic
    Delaware
    If you lose the DRL's you will also lose the auto-on feature, about the gauge light not working, it could be a blown fuse
    Hmm... could cutting the drl wire be the cause of that blown fuse?
    plu Well-Known Member
    SC
    It is the GAUGE fuse on the back of the storage door thingy on the left side of the steering wheel. I had the SAME THING happen to me when I disabled my DRL. I think it is because one of the cut wires shorted something. But replace that fuse and you will be okay.
    ohh okay, i should get that done tomorrow then, thanks plu!
    jtweezy New Member
    Irving, TX
    I"m guessing you didnt disconnect the batter..
    trdracing2005 New Member
    Portsmouth, virginia
    IM think the same as Jtweezy, same thing happened to me, cost me 175 dollars for land & Robertson to fix the solder the wire back and replace the fuse, thats when i knew nothing about cars lol. Lesson learned.
    it costs 175 to fix that?!
    yup , they charge out the ass there, they are the only electrical place around =(
    shit, im gonna have to see if the place around here will charge the same amount. hopefully not.
    lol I dont think they will. It is because they were the only car electrical place in a 100 mile radius lol
    you check your dimmer?
    of course lol :(
