DRL DIY with a switch non e-brake (link is up)
Discussion in 'Exterior' started by moonshadow, Jun 17, 2003.
    moonshadow ||\\|||D)||\\||
    Jersey City, NJ
    8) Well guys and girls, i got the DIY done. it was straightforward except for the pain to move around in the confined space. i will post it up later as i am back on dialup for the time being and the pics are being uploaded right now. there is one problem with it though tha we can't fix. see here is how the syste worked b4 i changed it
    DRL BOX --------------------RELAY BOX : in this situatio, the DRL box figured out if the car was on, the e-brake was down and turned on the lights. now its like this
    DRL BOX ------------- SWITCH ----------------- GROUND : after what i did, if the switch is toggled to on, and the car is turned on, the lights wont come on (toggle to on for disable system being on) but as soon as u turn the sysem off, the connection is complete and the lights come back on, but since the computer cant talk both ways, u cant trun them off unless u turned off your car, flipped the switch the other way and then turned the car back on. I will probably post up the DIY tonight after i get home from work and u folks can try it out.
    WARNING: the space down there is very confined so for those of you who will be cutting and stripping wires for the first time. but a lot of extra with a good strippper and practice. the actual wire from the box isnt too long so u dont have room to fuck up anything
    Achint
    P.S: check back for the DIY later today or early tomorrow and if u have questions, holla at me, info is in my sig :D
    Jersey City, NJ
    Here you guys go, here is the link for my 3rd DIY Mod
    http://www.cs.wayne.edu/~w20339/drldiy/drldiy.htm
    hope its as easy for u guys. this stuff definitely works very fool proof. i tried it at night just a few minutes ago and it does enable your auto light switch if u turn the system off.
    Enjoy and hit me up with questions.
    Achint
    Also thanx to stinky for clearing up a few doubts....
    U da man Anton
    alpha-vvti Member
    link doesnt work :?
    Jersey City, NJ
    ITS Fixed. thaxn alpha
    Jersey City, NJ
    yeye Guest
    Good DIY, thanks bro... Imma try it in a week or so...
    alpha-vvti Member
    nice low cost DIY :)
    i may try that later on when i got time
    Jersey City, NJ
    thanx guys, make sure u keep my warning in mind. i dont know what happens if u dont ground the cut wires. lol
    intel61 Guest
    hey to mount the switch, do we have any switch panels open in next to the mirror controls? i think if i can find a switch to mount into that space, i might find a way to do it. lemme know if we have any other switch spots
    yeye Guest
    Yea u gotta make sure the switch is small so it can fit..
    intel61 Guest
    yea i think i can find the switch at like pep boys or auto zone or some auto store
    also a question for the DIY, theres a wire that goes from the relay to the switch, and a wire from the switch to the ground. now if i flip it to the relay side, do the DRL's change according to the sensor? because the other main post said that as long as the wire isnt grounded it turns on. so does it work with the sensor?
    this is what i came up wtih, will this work or am i just plain crazy?
    so if i switch it on, it will continue teh circuit, if its off, it will go to ground?
    CorollaAudacity Guest
    When you grouded the yellow cable from the DRL box, what did you ground it to.
    just another stupid question, what did grounding the cable actually do?
    oh yea, i mounted a switch like that, well not exactly, well i put it right under the e-brake, you know that place where you can pull out, yea, it fits there almost perfectly.
    if you got a switch that has to branches, what happends to the incoming yellow wire, do you just ignore it?
    Jersey City, NJ
    well guys, let me explain the mounting a little better. after i spliced into the existing wire comming from the DRL module, i added the swithc and grounded it on the other side. i used a simple toggle on/off switch, i was gonna do a different one that lit up and stuff but chose not to go with it cuz a connection to the battery was required. as for the grounding, there is a metal peice with a lot of wires going to it as a grounding point. i just added mine to there as well. i havent yet figured out a place to mount it but i will probabl do it on the top opposite end of where the cigarette lighter is.
    Achint
    stinky Guest
    Intel,
    Your are on the right track to do that
    Just switch the location of the 2 yeelow wires. The center terminal on the switch is usually the common terminal. So you just need to put the wire coming from the DRL relay to that center terminal. Then put the ground wire on one outside terminal, and the other end of the yellow wire you cut to the other end of the terminal.
    Then for operation if you turn the switch to the side that the ground wire is on it will dissable the DRL's, if you turn it the other way it should enable your light sensor.
    intel61 Guest
    sweet thanx stinky, and hiro for the diagram
    hiro Guest
    intel,
    check your hot-mail
    i send new diagram for more ez understunding
    can you post that for all boys?
    cuz, i don't know how :oops:
    intel61 Guest
    yea hiro i got it, heres wat hiro sent me people
    Jersey City, NJ
    this is different from what i did, why do you have a second box and a extra wire???
    intel61 Guest
    its only one switch, hes just showing how it would look with on and off.
    and the wire just goes in, out, and ground. so if you switch to a, it compeltes the circuit, if you switch to b, it grounds it. i'll see if it works, if it doesnt, i'll do it your way achint
    Jersey City, NJ
    no it just confused me cuz i used a 2 connector toggle switch, and his shows the third prong with the extra wire. that is what is confusing me
    hiro Guest
    hi RollaCE,
    it's not second box and extra wire.
    it's used 1(one) DRL module and 1(one)new wire for ground
    and 1(one) 2-way/3pin switch for DRL/on and DRL/off,
    when turn to B-ON(right), DRL will gone
    and when turn to A-ON(left), DRL will work again,
    A-ON is just same as stock wire diagram,
    and B-ON is trick diagram for disable DRL,
    so, when you go toyota dealer for fix your car, turn to A-ON for stock look,
    then when your car back from dealer, turn to B-ON for disable DRL
    Jersey City, NJ
    here is how i did it
    Jersey City, NJ
    my question is on yours, the extra yellow wire that you have dubbed
    "yellow wire from harness to DRL module(cutted) is that the same harness as the one that i left hanging. BTW, my on off might be off. i have it figured out in my, when the switch is on, the DRL and light sensor is off, when the switch is off, the system is off. i gotta reverse the switch, but does that make sense
    hiro Guest
    ok, how about this?
    if peaple want to go back REAL ORIGNAL(stock) wire work, use 3pin switch
    if peaple just need ON-OFF for DRL, use 2pin switch
    but, it's only 2-3backs different on 2pin and 3pin
    so, i recomend to use 3pin for just in case,
    if you get some elc. trable and go toyota,
    they will check your system and can find CUTTED wire
    but if you use 3pin, they can't find it cuz 3pin has same as stock wire diagram
    but.. if toyota guy find and test the switch, both 2pin and 3pin will same :lol:
    Jersey City, NJ
    its the same exact thing, cuz the destination ground the stuff anyways but the current keeps flowing. also someone have the original wiring diagram for this stuff, i wanna better understand it and try and redo mine. one other question, the guy who started this thing with the othe thread, he had done the same thing as me right, and left the other wire alone??
    Achint
    Jersey City, NJ
    also, can you disconnect that wiring harness down there or is there a easier way to get to that stuff, the space down there is very confined or else i'd re do the DIY your way
    intel61 Guest
    achint, your way has that extra wire hanging. since the computer is "stupid", it doesnt matter, but you just wont have a wire hanging with the 3 pin switch. i'll try the three pin switch, and see if i can flip the DRL's off and on while the car is on, or if i need to turn the car off.
    just bought my parts, the guy at the local hardware store said i dont need to ground it if i'm just interrupting the circuit. they also didnt sell the three pin switch, all they had was two pin that flipped on and off, and four pin that had ON A, OFF, ON B. so i bought the two pin and i'll see what i can do tomorrow
    Since this doesnt really mess with anything when you put the toggle switch to off, it shouldnt mess with the warranty right? Right?
