Engine drilled slotted rotors
Discussion in 'Powertrain' started by locster703, Oct 26, 2005.
    locster703 New Member
    i see different cars with the slots on their rotors facing one way is there a right way they should be facing or it doesnt matter?
    sunrise_solara Guest
    Yes, the slots need to be facing a certain way...the sweep should be facing the front of the vehicle...in other words, travelling from right to left at an upward angle... Look at mine on http://www.cardomain.com/ride/561491 (that is the driver's side front)
    js10coastr Guest
    nah, doesn't matter. Either way the pads will get cleaned and the brake dust will be flung outwards... the only thing that matters is that the slots go all the way to the outside though.
    Cuztomrollaz98 MAD VLAD!
    Littleton, CO.
    this is so in the wrong section, is supposed to be in the suspension part.
