Does this happen to anyone elsE?
Discussion in 'Exterior' started by zcorolla, Apr 4, 2008.
    zcorolla New Member
    um lets see.....there is only one way to turn on your headlights if you dont have DRL's and that would be the knob on the left lever, as found in all cars.
    JazzMaster Guest
    hey... you american people has DRL on your cars???
    I disabled them on my car by cutting the DRL relay's red wire with a blue stripe
    EDIT : maybe you are from Canada I don't know and it's my bad if I assume that you are all from the US...
    DjiNN New Member
    I just bought my HID's and tried to put them in .. after turning on the car .. i get a static buzz from my car stereo system .. and my HID's flicker .. does this happen to anyone else?
    Edit:
    If you disable the DRL's how will you turn on your headlights?
    DjiNN New Member
    Okay .. If you disable the DRL .. how would u turn the lights on when u need them? by using the switch?
    DjiNN New Member
    Here's the difference in brightness ..
    rolla02 Corollalcholic
    Delaware
    Yup
    JazzMaster Guest
    w/DRL
    ignition : nothing
    after releasing the e-brank : low 50%
    1st click of the switch : low 50% + position lights on
    2nd click of the switch : low 100% + position lights on
    w/o DRL
    ignition : nothing
    after releasing the e-brake : nothing
    1st click of the switch : position lights on
    if you want, you can use a different switch for your DRL... just cut the red wire w/blue stripe and install a switch on the line...
    DjiNN New Member
    so .. if i disable my DRL's i would have to turn the left side in order for my lights to work? or would i have to add a switch like vamp did?
    JazzMaster Guest
    add a switch on the red wire w/blue stripe... its not that hard...
    DjiNN New Member
    well i know its not hard .. is adding a switch the only way i can turn on my lights? or can i just use the turn thing ..
    You don't know how to turn your lights on like normal people do? Don't tell me you actual drive with just your DRLs on. That is illegal.
    DjiNN New Member
    this is true .. i do .. bcz when i need to drive in the dark the lights are already on ..
    DRL's are really dim since they only run at a fraction of the voltage. Plus your parking lights won't be on which is a hazard. Get in the habit of turning the headlights on manually at night. You should disable the DRL's for HID's. You don't want to burn them out prematurely.
    DjiNN New Member
    but what about the strobe light problem?? is there a way to fix it?
    Edit : Nevermind .. i just spent about 1hr and 30min .. disabling the DRL and now it works .. no more flickering and no more buzzing sound
    JazzMaster Guest
    disable your DRL... its not that hard... DRL needs 6V (half of 12V) ... so if your voltage transformer needs 12V at the input and you give it only 6V, its not enough... it needs 12V no less no more... it's like a led.. a led needs .7V to light up if you give it less it won't light up and if you give it more, it will light too much and burn out prematurly
    DjiNN New Member
    night shots coming soon
    DjiNN New Member
