Engine Does anyone know this brand of Drive Axle?
Discussion in 'Powertrain' started by mingww, Jul 4, 2005.
    mingww New Member
    Vancouver, B.C
    my car shake like crazy when i drive on the hwy at certain speed/rpm. once i let go the gas or give more gas then the shakiing will go away. ususaly happen in 90~110 km/h range.
    there were too much play on the inner part of drive shaft.
    mingww New Member
    Vancouver, B.C
    I just took my car in for inspection, and i was told that my front driveshaft need to be replaced~
    Anyways~ The Price for OEM part is 541 CAD each side after 20% off they give me~
    Local Junk yard cost 195 CAD each side
    Repalacement Part I called for local parts store is 120 CAD each side.
    and the Brand Name is Fenco.
    http://www.fencoparts.com
    I'm wondering that have you guys ever heard Fenco? and quality of their parts?
    Thanks in Advance!!
    deeply appreciated~
    ChristianVA New Member
    what wrong with the axle..is it bent or crack! prolly its just the out cv boot that cut open. if thats the case. and the boot has been open for a quite long time...youjust need a new join and cv boot. its cheaper.
    You got so many problem on your car Ming!
    mingww New Member
    Vancouver, B.C
    what make you think my car have many problems?<br />
    stay on topic.
    statik New Member
    What wrong with everyone english? :p
    A halfshaft is what it is. Just remanufactured from OE. It really doesn't matter what brand. What matters is the WARRANTY. I don't know if you have carquest there or any affiliates. They offer a lifetime warranty on alot of their parts. I just replaced my CV driveshaft because the boot split open. It's much less trouble to buy a new shaft and replace it than to take the whole joint and boot apart. You'll be supporting recycled parts if you return your core. My shaft cost me about $85. The core charge was $106.
    * If your having someone do it, make sure the shop isn't charging you for the core as well as the part. Some people do that, and they are ripping you off.
    So you may pay about $271 CAD for the part (including core charge). Then when you return your old shaft you'll get $131 CAD back in your pocket. It shouldn't take more than an hour and a half TOPS for replacement of BOTH sides. I don't really know the economy over your way, but $541 CAD sounds kinda high. You could do it yourself, it's not too difficult.
    Good luck!
    Aren't you still haven't fix your MAF senior man? :p
    I think I saw somebody selling the axle for very cheap not long ago, let me check.
    ==========edit==============
    Try PM JDLangevin, he was selling them!
