Do you feel a difference with a strut bar??
Discussion in 'General Discussion' started by drivinfury, Feb 11, 2004.
    drivinfury New Member
    Bayside, Queens, New York
    i have ordered a strut bar....off ebay.....which i should be getting any day....but for the people that already have it....(only people with stock tires and stock suspension please reply) do you feel any difference driving?....also is it hard to install?
    AESC Guest
    well the strut bar was my very first mod when i got my rolla and it helped a bit but the stock tires really suck. after the sttut bar i got a trd dtop it helped a bit more but the big difference was changing tires.
    the strut bar is a simple process to install.
    there are three bolts under the hook above the wheel wells that is where the sptings are you unscrew the bolts and let the strut bar over the holes and reinstall the bolts. having a torque wrench is a good idea as it recomends some torque value i think 45 lbs but not sure run a search to find out the correct specs.
    CorollaX Guest
    29lbs of torque
    darrenwang Guest
    ?? Pizza.. hmm
