DIY Upper Grill Replacement
Discussion in 'General Discussion' started by ecorolla2003, May 11, 2004.
    ecorolla2003 Guest
    Anyone ? or is it really simple.?
    I should have my Vuteq grill by friday.
    nikeair11 Guest
    I have the Altis and not the Vuteq, but I assume they go in the same way. Take out the two screws with the rubber bushings, and then take out the screw in the middle connecting it to the hood latch. The OEM grill has snap latches on the bottom. Lift up on those and the grill should slide out. Pop in your new grill, and put all the screws back in.
    TJ Guest
    Where did u get the vuteq grill from and how long did it take for them to send it out?
    istylez Guest
    u can buy the grill off vpower.net
    ecorolla2003 Guest
    I ordered it on monday directly from vuteq. They expected to ship it today or tommorow and i should recieve it by monday. and its coming pre-painted. I think it was 135.00 painted and shipped.
    Thanks, sounds like an easy install.
