DIY DIY: How To Replace Your Front Engine Mount (98-02)
Discussion in 'Other DIY & Questions' started by plu, Jun 7, 2009.
    plu Well-Known Member
    SC
    Need:
    (2) 17 MM Wrenches
    (1) 10 MM Wrench
    (1) 14 MM Wrench
    (1) Front Engine Mount (Toyota #12361-0D011)
    Instructions:
    1) Take off the left and right engine under covers with your 10 MM wrench so you can see the front mount.
    2) Take off the long bolt that goes through the mount with two 17 MM wrenches. One on the bolt and one on the nut.
    3) Take off the two bolts circled in red with your 14MM wrench.
    4) Wriggle your old front mount off and put the new mount in through the top of the engine. Reinstall.
    As you can see the old mount had cracks in the rubber. The new front mount removed some clunking noises when I shift hard.
    tsburt Active Member
    miami
    nice...i'm doing my motor mounts this week. the mounts are in pieces, putting in some prothane mounts
    whiteline front sway bar?
    nice write up i think that time will be soon for me! [IMG]
