deck
Discussion in 'Interior' started by zcorolla, Jan 5, 2009.
    zcorolla New Member
    deck
    does anyone have a double din installed on their 8th gen? if so, where did you put it and does it obstruct anything?
    Des Plaines, IL
    Only way you can go double din is if you put in the cubby hole thing near the cup holders. I believe it is possible to put a double din down there.
    whydontyouchoos KFM
    Phoenix, Arizona
    not completely true, i have seen a modified corolla that had a double din where the radio is, they moved the vents to the sides of it, actually looked pretty cool, i belive they are on corollacustomz.ca
