Help! dash cluster replacement
Discussion in 'Other DIY & Questions' started by MovieSTAR, Feb 15, 2007.
    please =]. for 98 corollas
    cgreen38 Common sense, p
    Baton Rouge, LA
    It's really easy. Check your first thread. I gave a basic DIY (minus pics).
    Baton Rouge, LA
    It's REALLY easy. I thought it was gonna be hard when I did it, but it took ten minutes, and I couldn't be more happy with the results. Looks much cleaner than adding a separate unit.
    did you check out my link? did you have to remove your original speedo? or did the new one work just fine displaying mileage ect?
    Baton Rouge, LA
    You do have to take out the original speedo to retain the correct mileage. It's just 5 screws to take it out, then you put it in the other cluster and screw it back in. The link you found is the one I used to walk me through it, but he also tells you how to swap the gauge face. You won't need to do that.
    Ro2la New Member
    Los Angeles, CA
    Yep, if you want to keep your mileage, just swap out the speedo part. It's really easy.
    If you look at the center right part of this picture, you will see the five holes where the screws were that held the speedo in place.
    The speedo comes right out once these screws are removed.
    The new one drops right in where the old one was.
    Now you're mileage is accurate. That easy!
    Baton Rouge, LA
    Exactly. Took me like 10 minutes to do the whole swap.
    Cuztomrollaz98 MAD VLAD!
    Littleton, CO.
    I was lucky when I had my 98 lol I found an LE cluster with my exact mileage lol
    dward3 Well-Known Member
    Phoenix
    I bought the wrong one my first time around for my 01 corolla. Swapping the speedo wasn't to bad. ;)
    neat-o thx guyst
    PortCityRolla New Member
    I replaced my cluster in my 99, and now the turn signal light doesn't light up, and when I press my defroster, my left turn signal lights up. Anyone have this issue?
    modmonster2008 Complete Newbie
    how do u do this for a 93 rolla with a non-tachometer gauge, i want a tach on mine but idk how that would work
    Phan Well-Known Member
    Orange County, CA
    Lol
    geez reviving the dead my rear defroster bulb is burned out bt its no biggie
    Phoenix
    I must of moved the bulb when I used the cluster :)
    boredstudent3 New Member
    that's b/c only certain years go together. 98-00 and 01-02.
    i have a 98 corolla and i got a 00 cluster to swap in. you need to match one of the sets that i just mentioned. otherwise the wiring is different and you'll experience problems just like now.
    not true.
    proven not true.
    WorldHazard Member
    Silverton, OR
    i have this 'problem' with my cluster. swapped a corolla with tach into my prizm. my left blinker is my defroster light... are there answer to fix this?
    change the lightbulb............
    I should bump this, might get some traffic flowin
    That shit is gettong old, I was only bumping hummers threads to find the epic fail thread. I don't know why you think bumping old shit is gonna get us new members.
    we got one today
    Oooohhh I bet you are high fiving yourself aren't you.
    yuuuuuuuuuuuuuuuuuuuuuuup
    That looks like a fucking rock.
    treesprite New Member
    MD
    1995 Camry
    Sometimes people do searches on something they need info for, and it points them to relevant threads on forums. In my case, this thread is the type of info I'm trying to get, and had it not been, a search engine would not have led me to discover TRD forums. As long as these cars need work, the old threads will be relevant and useful.
    That said, I am waiting for a cluster I ordered for a 95 Camry. I have never done this stuff before, so am kind of nervous. I am wondering if there is any specific detail I should know for a 95 Camry LE before I do the swap.
    Thanks
    I don't think there are any active Camry owners here
