damn theifs!
Discussion in 'Interior' started by expatozzie, Apr 2, 2005.
    expatozzie Guest
    damn theifs!
    My wife's 99 Corolla just go broken into and the HU stolen.
    To be honest I can't say for sure which HU it was (I think an Alpine) as I never drove it.
    Anyhow...all the wires were cut at some stage and now all I have is a bundle of wires to wire up a new HU. (no harnesses remain on the old wiring)
    I stuffed around for a while trying to find the acc. power line, but could only find fulltime on!
    I have no clue what wires are for what speakers etc.
    Can anyone direct me to a wiring diagram for the '99?
    Alternatively, I need a location in the fuse box for acc power and a color code for the speaker wires.
    Thanks for any help.
    Mark
    Silver_Nitrate New Member
    FUNCTION PIN WIRE COLOR
    Accessory 12 Volt 3 GY
    Constant 12 Volt 4 BU/YW
    Chassis Ground 7 BN
    Power Antenna 8 PK/BU
    Remote
    Illumination 10 GN
    Dimmer 15 WT/GN
    FUSE VALUE FUSE LABEL FUSEBOX LOCATION
    15 AMP "CIG" DRIVER'S SIDE DASH PANEL
    15 AMP "DOME" DRIVER'S SIDE UNDER HOOD
    If the vehicle was equipped with an in-dash CD changer in the upper location and the AM/FM/Cassette unit in the lower location, removal instructions are located here.
    Left Front Spkr + 2 PK
    Left Front Spkr - 6 VT
    Right Front Spkr + 1 L.GN
    Right Front Spkr - 5 BU
    Left Rear Spkr + 12 BK
    Left Rear Spkr - 16 YW
    Right Rear Spkr + 11 RD
    Right Rear Spkr - 13 WT
    Back to top
    Video and Navigation Wires FUNCTION LOCATION COLOR
    Vehicle Speed Sensor Pin #4 of 16-pin plug beside and below heater controls VT/WT
    Reverse Light ( + ) Pin #4 of 11-pin plug in kickpanel junction box RD/BK
    Parking Brake ( - ) At parking brake switch RD/BK
    Brake Light ( + ) Pin #7 of 11-pin plug in kickpanel junction box GN/WT
    Hope that helps =)
    expatozzie Guest
    Thank you, a millions times thank you!!!
