cutting springs, anyone done it before?
Discussion in 'Stop, Drop & Roll' started by bennyboi9, Apr 2, 2010.
    bennyboi9 Well-Known Member
    Brisbane, Australia
    Okay so you all know im a cheap ass.
    My mate (mechanic with mechanic brother) has offer to cut a coil off my springs to lower my car. I think its a bit toooooo dodgy and am in doubt on whether i should do it.
    Let me know your thoughts.
    peace.
    He seriously said that to you? He shouldn't be a mechanic. You're right about thinking it's dodgy.
    Its not safe at all, the spring can pop out of the perch it sits on and the end can peirce your tire and then your fucked, however in the front sense the strut retracts into the hole it might be less likely unless you go off a huge pot hole, none the less its not safe. Do at your own risk.
    Edwin562 SWAG MASTER
    562 SoCal
    98 180sx
    they pop out, i had them for a month or so....
    if ur gonna do some work, do it right not some mickey mouse shit.... just wait and save up for lowering springs or even better some coilovers....
    truth, ur will fuk up car more with mickey mouse jobs than legit shit...trust me i learned the hard way...
    ExDream Member
    SoCal
    yeah if you do it wrong, your springs jump and pop out.
    out of ALL the things you do to the car, suspension is one place where you should never cut corners. glad you realize it's unwise. save up for a good suspension set.
    a person who can potentially endanger your life by recommending a dangerous mod i don't consider a mechanic.
    las vegas
    i did cut my lower spring "only" on the front about 10inch starting from the top to bottom and i havent had the experience that my spring pop out of the perch,i mean the only way i could think is only if you ramp hills or go over bumps super fast. the only annoying about cutting spring its very bouncy even alittle bumps or pothole makes the car bouncy and hanging turns is not a good idea. after 3months i upgraded to groundcontrol w/tokico blues.
    SaberJ2X Lurk MOAR
    Mayawest, PR
    :hesaid
    Cuztomrollaz98 MAD VLAD!
    Littleton, CO.
    What kind of mechanic says that?... Don't do it, too dangerous.
    JDMjody VVTLi > VTEC
    RIVERSIDE, CA
    04 Celica GTS
    Owned pic
    lol wut
