Engine Custom Mid-Pipe Done!
Discussion in 'Powertrain' started by Barnacules, Dec 18, 2007.
    Barnacules 100101101011011
    Duvall, WA
    My custom mid pipe (after the down pipe but before the catback exhaust) is now DONE! I have modified it to take an aftermarket wideband O2 (no more bolt on flange) and added and additional port for an EGT sensor. I also heat wrapped the whole thing! I can't wait to see how well it works.
    Pictures of the projects
    Heat Shielding off factory pipe
    Cut off the flange and grinded it down
    Hammed in bung
    Welded in bung and grided to find holes/leaks
    DId it again down stream for a EGT sensor
    Test fitted the O2 to make sure i didn't own the threads welding
    Sand O2 bungs and apply heat wrap
    Looks like I'm getting back in to the full swing of things.
    SaberJ2X Lurk MOAR
    Mayawest, PR
    excellent craftsmanship :D
    after I'm done fixing the whole car, (was a bit more fucked up than what I thought so) I'll be going a small turbo, straight to the liver blown 1zz-fe
    no IC, why? I live in the damned tropics, wouldn't do anything at all unless it's at night...
    and plus.... it's gonna be with a GT2860RS or something of that size so, even less lag
    ah.... 2 years from now/.... all I have to fix now are the brake system probably buy Dr.Tweaks rear disc convertion.... and fix the leaks here and there in the engine and then I'd be good for blown goodness :D
    jdmikey New Member
    that looks sick! good job!
    Very very nice.
    Duvall, WA
    Sorry I broke all the picture links, I'll fix them tomorrow if I remember :) Also the downpipe is now on the car and it is running. I posted a video for your enjoyment.
    I love my new Canon SD950, it fits in my pocket with my cell phone and has 16gb of ram so I take videos, pictures, etc constantly and upload them for forums and stuff. Sure makes life easy! I think I might write a little program that will automatically upload the camera when I plug it in to photobucket just to cut out the middle man :)
    dward3 Well-Known Member
    Phoenix
    I have to admit you have a nice turbo setup. Keep the videos coming too :D
    tsburt Active Member
    miami
    yup........love the setup.
