cup holder shaved
Discussion in 'Interior' started by trdracing2005, Jan 22, 2006.
    trdracing2005 New Member
    Portsmouth, virginia
    cup holder shaved
    is there anyway of removing the cup holder on a 98 corolla and covering the spot where it was with something so it looks like is was never there?
    sure, but you'd have to dismantle that entire lower part of the center console to get to it. if i recall it's held in with two screws.
    corollinout New Member
    just take the cover off, its held in by clips, if you take the ashtray out and pull it comes out. then its held in by 4 screws, holds the storage compartment and cupholder together. take the metal bracket off and the cup holder will come with it
    the blue part around the heat/a/c controls
    I did that , Thanks for the help on that part =) now How do I cover up the space left from were it was?
    e_andree E
    MD
    Use some fiberglass
    you could use fiberglass like e said, or use a piece of plastic, and use it for eletrical switcheds if you wanted
    e_andree E
    MD
    So where are you going to put your cups???
    I dont want drinks in my car and also how do i use fiberglass on the area to cover it?
    e_andree E
    MD
    Google DIY fiberglass...youll get the idea
    i'd just buy a half din plastic blockoff plate.. unless you really want to learn to fiberglass (not that hard) but the material cost would probably cost more then the blockoff plate.
