Engine Cruise control without cruise control
Discussion in 'Powertrain' started by SkyAce2004, Nov 12, 2004.
    SkyAce2004 New Member
    well, with cruise control, once u push in the clutch, it should dis-engage it
    CorollaULEV Guest
    So, I'm in 5th gear riding down the interstate. In fifth gear, at any speed over around 60mph: I push the clutch in and let off the gas but the engine rpms stay where they are. At around 70, the engine is at 3000rpm. I push the clutch and the engine stays right at 3000rpms like I'm giving it gas, even though I'm not. It eventually drops to idle, but takes around 10 seconds or so and does it and very slowly at that. Never happens in any other gear, just 5th.
    Any ideas why this happens? It's done it since brand new. Just kind of quirky I think but why??
    Late,
    Trav
    2003 Corolla CE 5-spd.
    91DX Guest
    maybe ur gear ratios has something to do with it?
    CorollaULEV Guest
    Well, yeah I know. The car does not have cruise control on it. It's a CE - no options other than the basics. When I'm on the interstate, it just feels like I have cruise control on b/c when I let off of the gas, it's like I'm still giving it gas - even though I'm not. It doesn't speed UP, but it doesn't slow down either. Then if I push the clutch in, the engine continues to rev at whatever rpm it is at for several seconds and then it slowly falls to idle.
    Doesn't do it ALL the time, but most of the time on the interstate it does this.
    Trav
    sxlostv1 New Member
    Los Angeles
    maybe you were going downhill?
    ... or ur throttle line/ throttle body was stuck
    CorollaULEV Guest
    no no no no. It only does it in 5th gear....never any other gear. It's something in the ECU tuning that causes it to do that. I've heard something about the EGR because when going from throttle to no throttle (lifting your foot off the gas), NOx emissions rise for a few seconds. I think it's some kind of safeguard to keep emissions down.
    Just curious what you all have heard.
    Trav
