Engine Crower Cams.... I don't get it...
Discussion in 'Powertrain' started by xplicitcorolla99, Feb 20, 2007.
    las vegas
    planning on buying it?
    jcrwzr Member
    Simi Valley, CA
    i want to do a head rebuild
    jcrwzr Member
    Simi Valley, CA
    a 1ZZ-FE is the motor in your car, so yes, these should work.
    pras211 Guest
    tell me bout the effects
    Silver Bullet New Member
    There are plenty of other good things to piss out $425 on.
    Vamp Gunmetal 2001 Corolla S
    Rosedale, MD
    Gunmetal Grey 2001 Corolla S
    I dunno if they're worth it. Check newcelica.org and see what people have posted about them and decide for yourself.
    If I have $425 to spend, I'll get a camcon. It's just me. :D
    JSPITZ New Member
    vA
    i have the stage 2 cams...i will be getting it tuned pretty soon
    pras211 Guest
    tell metooo how are they
    Oh good! So do you need to upgrade the valves and spings too?
    JSPITZ New Member
    vA
    no you only upgrade if you raise the rev limiter, the cams are great, I just need to tune...I run a greddy E manage Ult, and camcon
    JSPITZ New Member
    vA
    then you don't know what your talking about, why tune stock cams when you can get after market that will give you more power. come on people stop being cheap,...Go hard or Go home.
    Coz I know if I get the cams, then I'll have to buy a piggyback like e-manage. That's is at least another $300-400 + turning.
    For camcon, I can just buy it alone without other expense + turning.
    JSPITZ New Member
    vA
    even with the camcon you still need tuning, you can only get so much out of the stock cams. If you are not looking to invest money into modding the engine don't start, just do appearance mods. If you are going for performance don't halfass it. trust me on this
    OBX sells adjustable cam gears for the 98+ corolla for a much more affordable 129. Unfortunately the their site is down for construction. The product code is BX206.
