Engine cricket sound from engine bay????
Discussion in 'Powertrain' started by sean2sean, Oct 18, 2004.
    sean2sean Member
    so cal
    anybody know wut causes this sound coming from the engine bay? i just heard the sound today.
    and no... there is no cricket living in my engine bay... lol
    bad? good? normal?
    SkyAce2004 New Member
    theres a cricket in ur wheel fender!!!
    hehe sure its not a belt bro? LOL
    in my case i actually have cricket under my hood...
    a cricket on cocaine... it's called Greddy Type-S.... lol
    AFaceInTheCrowd Guest
    Knock Knock... j/p
    when you hear dice under your hood, we'll talk.
    RollaRyder1103 New Member
    Corona, CA
    just when car is runnin? or when off as well?
    CorollaULEV Guest
    loose/worn belts drivebelts. Probably worse in wet/damp weather?? If it gets worse or louder when you turn the steering wheel, then it's the power steering belt, otherwise it's the alternator belt most likely.
    Trav
