Engine Crazy Question: 98-99 engine in a 2002?
Discussion in 'Powertrain' started by corollakustom, Nov 7, 2005.
    corollakustom j-rolla what?
    Lake County FL
    Ok guys I have a what may be a crazy question, what would be involved in swapping a non-vvti MAP sensor'd 98-99 engine into my 02 corolla?.The reason I am asking is because my engine has over 80k on it and I have seen a few 98-99 engines for sale with less than 35k on them and I now that I would lose the vvti function but I would gain MAP sensor and it would be less complicated to convert to a return fuel system or run ITBs or forced induction.Am I crazy or can this be done?:superconf
    It can be done --- however... things to consider:
    1) your wiring harness will be no good
    2) your ECU will be no good
    3) your throttle body should be replaced
    If you replace both of those, and you get a MAP sensor (i happen to have a couple spares, LOL) then you're good to go.
    Lake County FL
    Cool do you know if I would need to get different motor mounts?.Also I was planning to install the corresponding ECU as well but what about my tranny?.Its an automatic and I know its controlled off the ECU what would I need to with that?
    Go manual!
    fastrolla96 speedbumps..yum
    Oklahoma
    good luck with that plan. I'm already having trouble going manual.
    I had ZERO issues going manual on a 98-02 series.
    Motor mounts are the exact same since the three primary mounts are on the transmission. Only 1 mount is located on the motor itself and that is the same from 98-02
    Oklahoma
    the issues I'm running into are just the hard to get aftermarket parts like my flywheel. Other then that its just peachy.;)
    ahh -- that figures
    Toysport didn't have anything you could use?
    Lake County FL
    Does the Celica GT or GTS auto trannys bolt on and are they stronger than the rolla's tranny?
    Lake County FL
    Hey vortex will i have modify my fuel system with this swap as well?
