Engine Couple O questions.......
Discussion in 'Powertrain' started by imported_Slipstream, Jul 3, 2004.
    imported_Slipstream Guest
    Couple O' questions.......
    First off, hi all, this is a great site and has helped me already.
    1. Anyone running 2.5 inch exhaust WITH and WITHOUT the resonator? What would you suggest.
    2. Anyone used the Cosmo CAI or SRI? Experiences....
    3. What are guys generally running and shifting their 2003 corollas at? Are you driving around at 4000rpm, higher or lower? SHould I shift at 5000 or 6000? What is safe. It is a higher redline than I am used to, except on my bike, so I am a little leary about opening it up.
    Let me know. I appreciate the help.
    TheBeak Guest
    welcome to the forum :) hope we can be of some help.
    1.) no idea
    2.) i have the TRD CAI, cant comment on the cosmo.
    3.) day to day driving shifts at about 3k. really running it, shifts at 6200. (a few ticks before fuel cutoff) you ought to try an XRS or a honda S2K, then youll be shifitng at 8000 and change.
    cmybootoo Guest
    1. dont know
    2. i love my cosmo. sounds much better and added good power cant really beat the price
    3. i shift around 3k on regular driving
    bewildered_spruce Guest
    1. there are a bunch of us running 2.25 exhausts and mine is with no resonator, dunno about 2.5 though
    CorollaULEV Guest
    The 1zz engine is capable of higher than 6450 rpms (redline on our cars). TRUST ME, if hitting redline on a regular basis would screw something up, I wouldn't have an engine left in my 2003. I hit the rev limiter all the time in my car and I've got 37,000 miles on it....done it since the car was broke in (1500 mi.). Never had a problem yet. Engine compression is still 200psi on all 4 cylinders (rings and valves in good shape). You won't hurt anything. It's a bullet-proof engine.
    Late,
    Trav
    Well, I took my Magnaflow back in today, had 2.5 installed from the second cat back and removed the resonator and I must say, I like it very much. Not ricey at all. Pulls a little better. Need a SAI. Very happy though. I would recommend the setup.
    As for shifting, I have been shifting around 4000 to 5000 under hard excelleration and 3000 to 3500 normally.... any problems with that?
    imported_borirolla Guest
    i say thats allright but dont be affraid to take it any higher than 4500 on agrresive driving its not gonna kill your engine.
    polo708 New Member
    9thgencorolla.com
    just your MPG... hahaha, drive it like you stole it!
    APC_MATRIX_ Guest
    Re: Couple O' questions.......
    1) I would go with a 2.5" exhaust with a resonator unless you want it stupidly loud.
    2) I have the Cosmo SR and it's ok, nothing special but it doesn't come with instructions, at all so be warned there.
    3) Run the piss out of it, the 1ZZ is a great motor and has the most power 200 RPM's shy of it's Redline, so yeah, don't be afraid to drive it hard :twisted:
