Engine Corolla Oil Pump Rating?
Discussion in 'Powertrain' started by Barnacules, Dec 1, 2005.
    Barnacules 100101101011011
    Duvall, WA
    I need to buy an oil pressure guage for my car so I can make sure my oil pump doesn't take a dump while I'm messing with my turbo :) But I need to know what PSI rating our oil pumps are so I can get the guage that is right for the job. This is the guage I'm looking at right now.
    http://www.sw-performance.com/products/product.aspx?productid=20
    Probably will depend on what oil viscosity you re planning to run. Service specs on oil pressure are 43+ PSI at idle and 43-78 PSI at 3000 RPMs. Run some thicker stuff and you might hit 100+ PSI at WOT. I don't it is a deal breaker, since most oil pressure gauges I've seen only read up from 0-100 PSI anyways.
    Duvall, WA
    Yeah I just wanted to make sure it didn't exceed 100psi. I'll get the 100psi guage. Thanks.
