Corolla '99 Help!!!
Discussion in 'Interior' started by ChristianVA, Sep 11, 2005.
    ChristianVA New Member
    its reallly easy. get all the screws out and pop it off. pretty much the only hard part which is not it taking the c clip off the window crank handle.
    VECorolla99 Guest
    Thanx but how many screws should there be?
    VECorolla99 Guest
    Corolla '99 Help!!!
    I need help, i need to know how do you take the door panel off to get to the speakers in a rolla 99. Its a VE so its manual not electrical
    fastcorolla New Member
    3!
    slvr2000fdvspec Guest
    take off the door handle - 1 screw
    door opening handle thing - 1 screw
    somewhere else - 1 screw
    slide the trim of the door opening handle thingy left or right and pull out
    turn the handle until you see this metal wire thing, use a flathead or panel popper and push it out but catch it cause that mofo flies far
    pull window crank handle out
    there are rivets all around the edge, so pop those
    after all done, push the panel UP and to the REAR of the car
    disconnect all wires
    place panel aside
    have a beer
    voila
    Spone76 Guest
    Yep it's not that hard I just but some speakers in my 00 last week.You are going to need a drill do get the rivits out of the speakers, or get a hammer to pull them out. Note: make sure the magnet doesn,t hit the window also the screw holes want line up.
