Engine Corolla 2003 intake fit in 2000 VVTI Engine?
Discussion in 'Powertrain' started by KhmerProduction, Aug 1, 2004.
    KhmerProduction Guest
    Quick question. I have a Corolla 2000, its running under a VVT-I engine, I've been looking for an Intake, something nice off of ebay...would a 2003 vvt-i corolla intake fit in mine which includes the MAF sensor?
    LoSx New Member
    2003 intake is the same as the 2000+ celica plastic intakes...
    and yes it will fit in there.. a little tough.. and youll have to remove the radiator hose and put it back on but it will fit
    Sweet, I just purchased one and I'll post it up to see what the outcome is like.
    LoSx New Member
    oh and i know it fits because I did it to my 2000 and helped a friend do it to his 99 which has a map sensor and is a bit trickier
    LowRolla Will work for turbo
    Oviedo, FL (orlando)
    are you talking about a CAI, cuz I would assume that won't fit the same, since the body style is completely different. I know my CAI for my 03 is much different from the CAI I had on my 99. A SRI should be fine though.
    I don't think the CAI would fit either...i was hopping someone with experience would b able ta check that...but im going to go with the short ram...the CAI is to risky and I dont really see much of a power difference but correct me if im wrong...
    d_samurai Guest
    not to mention potential water damage...IF you live in places with terrential downpoars and flooding..
    Darkness Guest
    so. . . a 2003 SRI would fit in a 2000? cause I am looking for an intake. . . I was also thinking about the Injen intake for an 01-02. Turborolla said it would fit but not much performance out of it. . . anyone have any other suggestions/ comments let me know what you think
    thanks
    cworkm Guest
    hey did you guys use the cheap one you always find on ebay, lke this
    http://cgi.ebay.com/ebaymotors/ws/e...&category=38634
    or was it different. I have anti-lock breaks and the strait rai doesnt fit right so i want the one like the one in the link above.
    pics would be cool to. thanks
    d_samurai Guest
    im not an expert with 98 and up engine bays, but i dont believe that intake will fit on 00-02 b/c of the looks of it...it looks like the filter will run into the fuse boxes...i know that 03 has a lot more room to play with w/o bumping into the boxes...
    I'm tryin it tomorrow morning with a friends AEM 03 model.
    System Error Guest
    I thought we were talking about intake manifolds at first.
    well, didn't fit. The battery is in the way, as well as the side of the frame. No way I'm cuttin a hole in the side of the car. In addition, the angle of the throttle body is different, so, it would sit lower in the car than an 03.
    cworkm Guest
    What about this one? do you think it would fit. its a bit shorter than the aem and fits different.
    yeah, that looks like the correct shape for a RAI like the injen one for 01-02 models. CAI wise I'm not sure you could find any that works well, the best shaped one I've seen is designed for a scion xB... curves around then back up front and drops downward.
    Darkness Guest
    yah same here......looking for a nice intake anyone have n e generic ones they willing to sell? for 2000 vvti
    Darkness Guest
    so would this one fit? sensor wise and all? cause there is only a day left and I would be interested in this intake. . . (the link in my previous reply above)
    cworkm Guest
