Engine Cooling performance?
Discussion in 'Powertrain' started by Gerson, Jul 26, 2008.
    Kansas City, KS
    Hi,
    I don't post much cause I know where 2 source most parts for our cars. But anyways, I am purchasing pieces little by little for my AE101 that I've been owning 4 almost 6 years to go back into it's former glory, while i'm getting another D.D. to work on it. Since I'm going to boost or do an engine swap, I like 2 know where to purchase a genuine Koyo aluminum radiator for our gen 7 corolla? I've seen trust/greddy, obx, arc super micro radiator ($1,000 wow!!!), and other brands sumwhere. I would appreciate it if I can purchase directly or a distributor that can get it.
    Thanx,
    Gerson M.
    las vegas
    sorry bro havent seen or heard Koyo aluminum radiator for the 7gen only seen it for the ae86 only...so what so good about Koyo aluminum radiator vs other name brands besides the $1,000 radiator?.
    SaberJ2X Lurk MOAR
    Mayawest, PR
    I have a koyo radiator in mine o_O OEM style though
    They make em in Japan but even those cost $600+ before shipping to the US.
    mooreofit New Member
    houston
    i "had " overheating issues with my turbo. i had mounted it about an inch from the radiator and it was boiling the water in the radiator and had to wire my condensor fan to the ignition +. a 92-00 civic aluminum radiator will be coming next week. and maybe a turbo heat sheild. i know pnky 33 has something similar. but you should be fine with the bottom mount exhaust manifold the one that relocates the oil filter.
    well i kept blowin fuzes so i rewired the posotive side and wired a switch on the ground side.
