coolant leak
Discussion in 'Care & Maintenance' started by m4tt, Jul 13, 2010.
    m4tt 2000 celica
    south tx
    coolant leak
    i have 2000 celica, it fills through the reservoir seperate from the actual radiator. when it gets warm the fluid starts dripping from the cap so i slowly open the bleed valve until fluid comes out there but it just constantly leaks out the cap. i got a new cap and no luck
    SaberJ2X Lurk MOAR
    Mayawest, PR
    new radiator top or a whole new one... epoxy shits are that... shit...
    take it to a radiator guy to open it up and try to fix it as a "meanwhile..." move
    KrypticKarma ~2001 Corrizm~
    Oshkosh WI
    DO NOT put stop leak in your radiator. you will regret it
    m4tt 2000 celica
    south tx
    it dosnt leak from the radiator. i have a reservoir that has hoses to the rad... its like your overflow tank i guess. i drive a celica
    Oshkosh WI
    Okay just sayin lol. That stuff does more damage than good. You should really post some pictures. This is forum of mostly corollas and some of us might not know what you mean with the whole reservoir issue. Then some of use might be able to share some advice
    m4tt 2000 celica
    south tx
    are you sure you're not putting too much fluid in? if so, i would suggest what someone else suggested and get a new radiator top and possibly a new cap. have you ever replaced the radiator? how many miles on your car? it maybe time for a new radiator anyway.
    m4tt 2000 celica
    south tx
    the engine has 20k and the radiator is almost 180k. i completly drained the radiator when i swapped engines and so far ive only put a little over a gallon back in. i bought a third cap today, an oem cap, but it still leaks just out the back off the cap instead of the front with the other 2
    SaberJ2X Lurk MOAR
    Mayawest, PR
    it's the pvc of the top... mine cracked due to reasons unknown before I getting it...
    and it wasn't visible but when pressured builded up it leaked
    m4tt 2000 celica
    south tx
    haha your right i just got in from the garage and i wrapped thread tape on the cap and it held for awhile then started to drip slowly. im ordering a new reservoir tomorrow
    m4tt 2000 celica
    south tx
    so i have a new reservoir and three caps....it still drips. now im starting to think im doing something wrong
    bennyboi9 Well-Known Member
    Brisbane, Australia
    ugh, you sure thats not the overflow tank? when the engine heats up the coolant expands. the coolant from the radiator goes into the overflow tank thus causing it to.. overflow. If the engines not heating up, who cares. Just make sure it doesnt drop too low, and when it drops to a certain level where it doesnt leak, just fill it up to that level from now on. maybe?
    dward3 Well-Known Member
    Phoenix
    try bleeding your coolant system... :D
    i still think its your radiator. its old and not able to maintain the pressure.
    m4tt 2000 celica
    south tx
    i had a hose hooked up wrong i bled it right and everything
