Engine Complete Short Circuit
Discussion in 'Powertrain' started by Toxinate, Jun 25, 2005.
    Toxinate New Member
    Okay... Me being the idiot I am decided to cut a power wire while the connections were still on the battery. Needless to say, the bolt cutters I was using touched the chassis of the car... Spark, Spark... etc. etc. The power in my car goes out... Of course, all the accesories were on.
    Few questions: 1. I checked the relays and 4 of them appear to be out. They click everytime I put each in with current running. (Does this mean that it is blown?) The fuses are still intact.
    2. What other maladies will I have to address? I pulled the relays and absolutely nothing really works, except for a few lights on the instrument cluster that glow dim.
    As of now, my battery is disconnected. Any help's appreciated as I'll be installing subwoofers tomorrow and need my car up and running ASAP.
    Dr Tweak Mad Scientist
    Savannah, GA
    That doesn't mean the relays are out. You checked ALL of the fuses, even the big main fuses? It sounds like a fuse.
    -Doc
    Toxinate New Member
    Yes, I checked the fuses. The thing is, 5 relays click everytime I reconnect the battery terminal. They never did that before.
    Some relays and crcuit breakers can be reset - you can tell if take one and turn it over - there will be a little hole in the bottom. Stick a paperclip or similar in there and push to reset. Otherwise - I believe that there are some fusible links in there that might have let go. Relays that click mean that some juice is getting to them, but maybe not enough or the relays are shot.
    Toxinate New Member
    Where exactly is the fusible link located in the engine bay? The more description the better.
    what year corolla?
    Toxinate New Member
    2 boxes on the drivers side engine bay and 1 at the front bumper on the passenger side.
    then 2 inside the car.. one on the left and right kick panels.
    I'd start by checking 'EFI' which sits the furthest toward the back of the fuse box closest to the firewall.
    Toxinate New Member
    I meant the fusible link cable, not the fuse boxes. But thanks for the info anyway.
    New Information: I began resetting the relays and electrical systems are coming back on. Does anyone know the locations of all the relays in a 94 Toyota Corolla?
    sorry.. never heard of a fusible link cable
    Rolla95 Rollin' Out y0
    Deptford, New Jersey
    to much Haynes manual for you :eek:
    actually it's the OEM wiring manual :p
    Toxinate New Member
    Next Problem: Everytime I turn my car on, there are buzzing sounds coming from the relays? Any clues as to what's going on?
    Update: Any component that draws a substantial amount of electricity will reset indefinately. ie. turn off, turn back on. Any ideas?
    Savannah, GA
    Wow, you really screwed something up good. If you don't have a good understanding of how the diagrams and wiring works, then take it to a shop. If you don't have the diagrams, don't go any further...
    Toxinate New Member
    Problem Solved.
    Solution: Went around and reset every relay in the car. 4 in the main fuse box, 2? in the secondary fuse box, and 3 in the fuse collection under the driver's kick panel. I also went around, disconnected a few connections, reconnected them, and finally disconnected the alternator and reconnected it. This was for a 1994 Toyota Corolla Automatic. Direct short circuit from the positive terminal to the chassis while the car was on accesory mode.
    Thanks for your help guys, Greatly appreciated. Nice forum you got here as well. Great ppl.
    Toxinate New Member
    Well... I woke up to a dead battery, so there's a short somewhere still. A few issues arose like yesterday but not as comprehensive. Still cannot crank the engine, so I'll be back at it and keep you guys posted with information.
    Any help would be appreciated again.
    Problem: My defroster light comes on and stays on whenever I connect the terminals. The interesting thing is, when I remove one particular relay under the driver side dash, the light goes out. Anybody know what's up with that?
    New Post (2:30:(
    Alright: Checked all the relays, two weren't working like they were supposed to. Fixed them, plugged them back in. (That may solve my electrical discharge problem, however now everytime I connect the terminals, the engine wants to start. I removed the power to the starter, and now there's a loud click everytime I connect the positive terminal somewhere around the back of the engine. It appears that everytime I remove a relay/unplug wires, current is trapped in a loop somewhere else. Some things are operational while others go out and "random" lights display on my gauge cluster. IE. oil indicator lamp for one loop, defroster lamp for another...
    I just about unplugged every relay in the car, and every wire connector in the interior.
    Does anybody have any clues as to what may be the issue now?
    New Post (3:33:(
    Okay my car is quickly turning into one of those Myst puzzles. Apparently, the order in which I connect the relays matters. That may explain the problems I'm having with various electrical equipment jumping around the vehicle. If anyone has any further understanding of the particulars of the car electrical system, specifically for a Toyota Corolla 1994, much help would be appreciated.
    As of now, I'm connecting relays with a voltmeter connected to the battery watching the voltage drop/rise/stay. I feel as though I'm that guy in Apollo 13.
    New Post: (5:53)
    Update: I got the majority of power flowing where it should, the interior... I'm playing around with the interior relays, only I can't seem to find a combination that works... If I can't find a way by tonight, I'll end up towing it to the toyota dealership tomorrow. So quickly throw in any comments/suggestions/insights/epiphanies.
    put all the fuses in.. then hook the battery :superconf
    Toxinate New Member
    My car is currently in the Toyota Dealership. It costs $350 just to look at the problem. And possibly upwards of $3000 if a computer is fried. Anybody think insurance would cover this? I do believe I have everything but collision.
    Toxinate New Member
    Word back from the dealership:
    Total Cost: $550
    Diagnosis: When I short circuited the engine, power went directly to the chasis. Luckily for me, the 3 Gauge(!!!) grounding wires I had installed a few weeks before took the hit before anything else could.
    The only thing that is gone is the Alarm System, so $350 for the initial check of the car and $200 to remove the alarm and replace 11 or 15 wires.
    Getting the car back tomorrow or Thursday... Just in time to build my ported box and install my new Pioneer/Premier Amplifier and 10" Subwoofers. Woot.
    numines New Member
    god dman dealership and their diagnostic fee... 350 to tell u what the problem is? jesus...
    i feel bad for u
    Toxinate New Member
    Got the car: The final price came to be $795 + tax.
    5 Relays were blown, however they didn't appear to be when I was fixing the car... And I just opened one now and it appears to be fine (wtf?)... Anyway here are the five: Defroster, Fan, EFI, Taillight, and AC.
    Started to put back the electronics in the car, Radar detector, Radio, Buttons on the panels and everything appears to be in working order except the defroster.
    So there you have it. One mistake turns my stereo system into a $1400 stereo system where it should be $600.
    At least I got to keep the damaged relays. Gonna check them and make sure I wasn't screwed, considering the relays are $85/piece.
    I'm gonna test them, open them up and fix them if they're broken. So if anyone's interested in any relays for a 93-97 corolla, I got 4 of em since I'm gonna use one. They're the black headed, single throw, 4-pin relays. Toyota Relay ISO M4-S
    AE102 New Member
    everythings all good. just remember that next time when you mess around with electrical wirings....i've learn that the hard way lol. cost me time and money.
