Comments pls.
Discussion in 'Interior' started by triune530, Dec 9, 2004.
    triune530 Guest
    Comments pls.
    http://www.electronixwarehouse.com/...amid/808-sp.GIF
    Pyramid #808 10 Band Graphic Equalizer Amplifier with Echo/Reverb
    * Echo/Reverb System w/Adjustable Slide Control and Bypass
    * 12dB Boost/Cut
    * Power On/Off Defeat
    * 2 Channel High Power Amplification
    * 2 or 4 Speaker Hook up
    * 300 Watts Rated Power 2 x 150 Watts
    * Dual Multicolored LED Power Meter Display
    * Fader Control
    * Night Illumination Around all Controls
    * High Impedance Input: 100K Ohms via RCA Jacks
    * Low Level Input: 100 Ohms
    * Common or Floating Ground Hook up
    * Frequency Response: 20Hz-20kHz
    * S/N Ratio: Better Than 70dB
    * Output Impedance: 4 Ohm (4-8 Ohm allowable)
    * Dimensions: 7”L x 51/2”W x 11/2”H
    List Price: $99.95
    Our Price $79.95
    triune530 Guest
    No comments yet???
