Cold Air Intake for a 3 speed auto
Discussion in 'General Discussion' started by DrunkSaru, Jul 19, 2007.
    Kinda off subject.. sorry but 3 speed with CAI reminded me of a car i saw a week ago. A corolla all banged up and had an intake and exhaust. Looked very Mexican (some of you know what i mean). ANyway that car had a bumper sticker that said "My car is loud but it gets 50mpg" .... I thought it was pretty cool
    haha even if it did get 50 mpg I still wouldn't be caught dead in it.
    bells Guest
    Can anybody out there recommend a good cold air intake for a 1998 Corolla with a 3 speed automatic? Is it okay to put one on with a 3 speed to begin with? Also, where can one find a decent front spoiler/lip and a front sway bar at a reasonable price?
    daniel2002p Guest
    CAI dont care what kind of tranny u have you just have to find the one with the right diamter and proper holes for the MAF ans such
    D
    bells Guest
    Thanks for the info. Can I ask what the MAF is?
    Mass Air Flow sensor.
    get the weapon-r...as far as i know they are the only ones that still make them new for 98's...
    eddy Well-Known Member
    OR you can get a used EL Prototype on one of the Toyota forums.
    yeah used though...i wouldnt buy used engine parts though...but its up to you realy
    There's nothing wrong with a used intake. There are no moving parts to wear out. All you need to check for is rust.
    Especially rust on the inside. The one I bought from a guy on this forum has quite a bit of rust on it, but I sprayed a whole lot of rust converter on it. So far so good, but I still have some work to do on it.
    93geoprizm Active Member
    intakes on auto trannys should be banned lol
    Rust in the intake??? You sure that was rust? I thought all intakes are made of aluminum.
    I guess someone was being too cheap and bought a no name iron one in the first place.
    still havent but a bypass valve on mine..but probably will eventually
    shubert_ae102 New Member
    de mountains :D
    just trash the filter that comes w/ it and get another one , if its the foam element , weapon r is known for there filters crumbling and going into your intake.
    i heard that from a few people too, so far i havent had a problem with mine but i keep it clean
    nocpan New Member
    intake is intake, I'd get any intake since its just a bent aluminum pipe, but I'd invest into a decent cone filter at the end so something by K&N or HKS or something like that. Don't forget about the bypass valve so the water don't get into your engine.
    It is an ELP, not a no name.
    ic ic. Didn't know that ELP is using steel for intake. I thought all intake tubes are aluminum. Learn a new thing today. :D
    Well, it was a custom make intake so steel is one of the easier and cheaper ones to weld.
    jcrwzr Member
    Simi Valley, CA
    i don't know what the material is, but i just installed an AEM CAI on a 2006 civic SI. WOW talk about an upgrade. anyway that thing was SUPER light!!! and compared to my ELP CAI for my corolla, the AEM is 75% lighter, i'm almost certain
    Can you mandrel bend an aluminium pipe in the shape of the ELP?
    The intake weight is negligible though. It wouldn't affect anything.
    nocpan New Member
    yeah but using steel? unless its stainless steel then i'd worry about it rusting and rust getting into the engine. And with aluminum intakes so cheap on ebay you just buy 2 or 3 long pipes and can easily assemble your own custom CAI.
    Yeah, that is true. I forgot the take the heat sink theory into consideration. I'm not sure how aluminum would compare to steel.
    de mountains :D
    <br />
    ahhh , but the metal is a factor . you want the metal that will act less as a heat sink. the most heat resistant metal.<br />
    <br />
    i know i used galvinised steel for mine (haha 3&quot; drier pipe <img src="http://vvti.net/forums/images/smilies/biggrin.gif" border="0" alt="" title="Big Grin" /> ), and just coated the inside w/ oil in a spray bottle. 2 years old and still fine , no oxidation or rust . the zinc isnt even starting to powder.
