Codes P0441 and P0505
Discussion in 'Care & Maintenance' started by jtweezy, Oct 14, 2006.
    jtweezy New Member
    Irving, TX
    Anybody have these codes before?
    I understand P0441 is about the purge flow in the evaporative emission control systems is incorrect ...but what part(s) should I look at to replace?
    P0505 deals with the Idle control system....so what part(s) should I replace?
    igorien2k New Member
    P0441 is the same one that i have. 8th gens have a common problem with one of the purge valves. go to the junkyard and buy both valves and the sensors attached to them. couldnt be more than $10.
    as for P0505, does your car idle normally? any cold start problems? when you start it the revs should be around 1800-2000 RPM and should quickly drop to 1200 and then to 800 when warm. It could also be a leak thats only open when the engine is cold. I would watch over your idle and check the throttle body and piping for leaks and check the little paraffin ball, or whatever its made of that allows more air when cold and closes the opening when the engine is warm
    Rolla95 Rollin' Out y0
    Deptford, New Jersey
    one code could be promting the other code though, u gotta isolate what one is really causing the problem
    Des Plaines, IL
    Also just to let you know that you posted this in the Tundra forums lol.
    YamahaTundraV8 New Member
    Atlanta (burbs)
    Yes indeed but Tundra have O2 problem's and there own set codes :mad: :mad:
    dward3 Well-Known Member
    Phoenix
    Here's those DTC numbers and trouble areas to check.
    P0441
    Evap Emission Control System incorrect purge flow
    1. Vacuum hose cracked, holed, blocked, damaged or disconnected
    2. Open or short in vapor pressure sensor circuit
    3. Vapor pressure sensor
    4. Open or short in VSV circuit for vapor pressure sensor
    5. VSV for pressure switching valve for vapor pressure sensor
    6. Charcoal Canister cracked, holed or damaged.
    7. Fuel tank over fill check valve cracked or damaged
    8. ECM
    P0505
    Idle Control System Malfunction
    1. Open or short in IAC valve circuit
    2. IAC valve is stuck or closed
    3. Open or Short in A/C switch circuit
    4. Air induction system
    5. ECM
    jtweezy New Member
    Irving, TX
    thanks for a detailed list
    ever figure out why this was happening? I'm getting the P0441 code and now have to fix that too.
    yeah i have both codes now actually..
    right now, i have 3 codes
    p0420, p0446 and p0505
    ugh.
    yeah I printed out the 20 pages from the repair manual on the subject. hopefully I'll get to start testing parts this weekend.
