Engine clutch??? what should i get..
Discussion in 'Powertrain' started by sAc_Rolla, Nov 9, 2004.
    sAc_Rolla Guest
    i need to get new clutch for my 94 corolla 5 spd....1.8L.... im not sure wat will be good... help...thanks
    slvr2000fdvspec Guest
    do you want a stiff ass mofo clutch? or just one to drive around on..
    corolla_racer Guest
    i have a ACT stage 2 clutch and i love it man but its up to u if u have the money or notfor it...
    sAc_Rolla Guest
    i want sumthing that is not too stiff ...i was thinking centerforce or act....i want sumthing better then stock...
    Mike4831 C-Town Pimp
    Statesboro, GA
    What do you have under your hood that woulde require you to have a stage 2 clutch?? I really don't think it is helping your engine out.
    sAc_Rolla Guest
    how do u knoe if ur clutch is bad..
    sAc_Rolla Guest
    http://www.performancecenter.com/pr...ations&sf5=1.8l
    what would be a good one for normal driving a racing.... i was thinking ...
    Street Disc & Heavy Duty Pressure Plate Clutch Kit...
    4-Pad Race Disc & Heavy Duty Pressure Plate Clutch Kit....
    FX100 Steel Back Heavy Duty Street Clutch Kit ......
    or maybe centerforce...but then i have to get the release bearing so .....
    corolla_racer Guest
    will if u are going turbo soon down the road got stage 2 but if not just go got the stock clutch kit again it will least u for a long time.....WIll hey Mike4831 i have a 95 corolla turbo and thats why i have a stage 2 clutch and by the end of winter my motor will be fully re-built and done....
    Pantaloon007 Guest
    The stock clutch and pressure plate can handle up to 233 ft/lbs. Youd be just fine with a remanufactured clutch from Toyota($70.00) a pressure plate is about 100. Wait till you get the NO2 and turbo together before you worry about clutches...
    sAc_Rolla Guest
    ne more input
    CadetLee Guest
    Are you sure? The ACT heavy duty pressure plate/organic disc setup holds 233ft-lbs as well..
    It grabs, though -- my OEM one didn't like to..but then again, it did have about 130k on it. :p
    baddrunk69 Guest
    I'm thinking about getting an ACT HDSS clutch
    http://www.prostreetonline.com/buy/..._Duty_Clutches/
    The model number for our corollas are TC2-XXXX where XXXX in my case is HDSS.
    What I want to know is how reputable is the company and is there anything out there for less?
    $318.41 -10% $31.84 = $286.57
