Clicking noise after installing springs...plz help!
Discussion in 'Stop, Drop & Roll' started by GT-R, Jul 12, 2004.
    GT-R Guest
    I installed TRD lowering springs onto my car with a friend.
    It was an install job from hell that took us almost a day because the spring compressor was so crude and abused and we kept trying to rush it by compressing one side a bit more before compressing the other but ended up decompressing it and then recompressing all over again and doing it right.
    But anyway we finally got it done and everything seemed good, despite the slight pull to the right sometimes when I am stopping. I planned to get an alignment done after a month or so of riding around and letting it settle.
    But then I began to notice clicking noises everytime I went over speedbumps. I ignored it for a while thinking that it was normal. But some of my friends have lowered cars. None of them seem to be doing that and their cars are lowered even more than mine.
    Is the clicking noise while going over speedbumps normal? It seems to be clicking when its rebounding after being compressed going over the bumps.
    I'm just worried that something didnt get tightened enough or something during the install.
    Can anybody help me out?
    polo708 New Member
    9thgencorolla.com
    you might have cut the bumpstop wrong :?
    GT-R Guest
    They're TRD springs, I thought we weren't supposed to cut them at all?
    polo708 New Member
    9thgencorolla.com
    Is that what the instructions said? I dont know... I have Tein
    brownbanana ToadMotorSports
    Oahu, Hawaii
    yea, i think only tein stech you gotta cut the bumpstop..not sure bout htech though. i know that hotchkis comes with their own bumpstops but from what ive read,im pretty sure you wouldnt need to cut it with TRD springs
    GT-R Guest
    Yeah, I'm wondering if anybody else with the TRD springs have this noise?
    Tenchi New Member
    I installed TRD springs and I do not have that noise. Did you torque down everything to specs? Also check the rubber, I guess you would call it a gasket, that goes between the spring and the top of the assembly in the front two. I remember that when I was tightening everything, as I turned the top bolt (of the spring/shock assembly), it turned the top cover and the rubber gasket got out of place. That would leave a metal (spring) to metal (top cover) contact.
    Am I making any sense?? :oops:
    GT-R Guest
    Everything was torqued according to spec except the back, and I couldn't find the torque specs for any of the parts in the back so I just torqued it pretty decently until I could get a alignment and get the specs. That cover thing makes sense...I'll check it up this weekend, thanks. Just curious though, have you gotten an alignment done?
    Oahu, Hawaii
    i have Tein STech and did not torque back to spec any bolts and have not gotten an alignment..thank god everything has been good and i have had no problems :D ...knock on wood :shock:
    RollaS New Member
    wow, that's either really brave or really dumb......i haven't decided yet.
    Oahu, Hawaii
    haha, brave and lazy..i am totally aware of the risks but everything has worked out..i wouldnt recommend it to anyone and i am gonna do it the right way when i lower my next car
    RollaS New Member
    the alignment isn't that big of a deal, unless your tire wear is bad............i'd just be scared to drive my car at high speeds w/out knowing if a bolt is tight enough. Hell I torqued em to the right specs and I still not sure if my car is safe, just because I'm the one who did the work
    Oahu, Hawaii
    we toruqed most of the bolts with an impact wrench so we were kinda confident they were on tight enough. i was sill a little uneasy, but its worked out all right...but i have learned a lot since then, next time its gonna be torqued to factory spec
    GT-R Guest
    I know exactly what you mean....Just because I'm the one who did the work on my install it I feel a bit uneasy. Even the small clicking sound gets me all paranoid. You wouldn't happen to have to correct specs for all of the rear bolts would you? I couldn't find them anywhere and I asked my dealer, they said that they don't have access to it and that I would have to go ask at an alignment shop. :roll:
    oxymoron Guest
    Toyota has the specifications - they're in the Toyota Service Manual under Service Specifications. CorollasBest has a copy of it on his website.
    GT-R Guest
    I can't seem to find it on corollatoys. Am I looking in the right place?
    Tenchi New Member
    Yeah, I had my alignment done about 2 weeks after I did the installation. It gives the springs some time to settle a bit (if any).
    oxymoron Guest
    CorollasBest posted the link in this thread:
    topic 7546
    GT-R Guest
    That was tricky....lol
