Engine Check Manual Transmission Fluid Level & Clutch Fluid Lev
Discussion in 'Powertrain' started by macaddict, Jun 18, 2004.
    macaddict Guest
    Hi,
    Does anyone know how/where we can check these levels on a 03 Corolla with a Manual Transmission?
    I've looked through the manual but it doesn't mention it.
    Thanks.
    -Mario
    Schoat333 New Member
    there is a large nut on the front side of the trans... 15/16ths wrench fits it... that is the check/fill hole then underneath there is a nut the same size at the bottom rear of the trans on the drivers side of the trans... this is the drain plug. heres some pics
    fil and check plug
    Drain plug
    macaddict Guest
    WOW!!!
    You went and took this pics for me?
    THanks man.
    How about the clutch fluid?
    -Mario
    the clutch runs off the brake resivoir.. so just check the brake fluid and thatyll be for clutch also
