Engine CHeck Engine !!!!!
Discussion in 'Powertrain' started by AFaceInTheCrowd, May 13, 2004.
    AFaceInTheCrowd Guest
    take the bulb out.
    TCS-Mike Guest
    CHeck Engine !!!!!
    My "Check Engine" Light came on today, I pulled over and did not see or smell anything wrong. I checked the oil and it was fine, I looked for oil leaks and found nothing. The engine is running fine, Sounds normal. Can't find anything wrong...... What could it be?. And ideas?, Anyone have the same problem?, What did you do?.......
    Thank you
    rolla02 Corollalcholic
    Delaware
    go to autozone, the will check it for free
    Mike4831 C-Town Pimp
    Statesboro, GA
    prob a bad o2 sensor. but i know at honda 9 times out of 10 the check engine light comes on because there gas cap isnt tight enought. and believe it or not it cost them 72 dollars for a tech to tell them that.
    TCS-Mike Guest
    I took off my cap and checked it, It is tight and the light is still on. Do I have to reset the Engine Light?. I am gonna replace the o2 sensor,PCV and the plugs this weekend. Got to be at work at 7am tomorow and got no choice but to drive it. How much does o2 sensors usually cost?.
    CraigW New Member
    If you pull the battery for a bit it will reset light.
    You dont mention year?, my 00 was a MAF sensor.
    CW
    corolla_man_j Guest
    yea...what mods do you have....mine is wierd...with my air intake, if I let my car idle for more than 3 minutes I throw the CEL but then if I drive it for a while, it goes back off
    TurboRolla21 Guest
    I just had to buy a new one... $125
    d_samurai Guest
    if you dont know how to install it yourself-on a 93-97 corolla-i think you have to take out passenger's seat-to disconnect the cable-son of a...either try with haynes manuel, or go to dealership or some shop-be ready to pay over 200 in labor! its a large project!
