Engine check engine light
Discussion in 'Powertrain' started by d_samurai, Jul 18, 2004.
    d_samurai Guest
    ok, did you do anything do your car to cause the problem? 1. exhaust work 2. mess with the fuses 3. mess with o2 sensors 4. mess with your cat converter...
    coolmoe Guest
    check engine light
    my cehck egine light keep comming on and i went to go get it check and everything i need help help with it
    coolmoe Guest
    i just got the cat replace
    Fox New Member
    Under your sink.
    there you go then...
    check the cat sensor btw
