Engine check engine light on 01 corolla, got the OBD2 read
Discussion in 'Powertrain' started by Jerry, Jun 18, 2006.
    Jerry Guest
    plugged in an OBD2 reader and it sayed "Evaporative Emission Control System Incorrect Purge Flow"
    So if anyone has any tips, or knows what the problem is and how to fix it. Any help is appreciated.
    If you do know what the problem is, should i attempt to fix it myself, i'm a novice when it comes to working on cars.
    Thanks alot guys.
    SleepinRolla Member
    Socal
    thgiten your gas cap
    Jerry Guest
    alright it seemed to be on properly, but i removed the cap and put it bag on.
    now if that was the problem should i wait to see if the light goes off in the next couple of days, or should i reset the check engine light and see if it comes on again?
    SleepinRolla Member
    Socal
    it think your better off reseting the light cause the car only testthe EVAP system under certain circumstances it may be while till you repeat the needed situations.
    igorien2k New Member
    our cars have a problem with one of the purge valves. when you open the gas cap to refuel is there a vacuum? if there is its probably the valve thats not opening. i'm not sure which one it is, but if you go to the junkyard just buy one and pocket the other. another thing you can check for is the integrity of the hose that goes from the canister to the manifold with an air compressor.
    yngrolla Guest
    could you tell me what a bad mis fire is?
    SleepinRolla Member
    Socal
    one or more of your plugs isn't firing
    felixrolla Guest
    it might be the charchol vapor canister. I have that CEL and I just delete it.
    ^the vacuum is a bad thing? I always has it when I open the gas cup. :(
    Why is it bad?
    Live2drum New Member
    ya i have that too some times when i open my gas cap . wahts up with that? i sit bad
    does any one know about this vacuum?
