Chassis Stiffening
Discussion in 'Stop, Drop & Roll' started by 1nicetrd, May 26, 2014.
    So i have been trying to figure out something different for making the body more rigid. Without getting a massive amount of bars and braces or even a cage.
    So i found Foam ! i am still looking at which ones work best. But the best part is that the foam has a few benefits, it stiffens the chassis, sound deadens and also it is lightweight.
    This diagram shows you the key places to inject the foam
    Sample foam
    This is just a idea and wanted to share. Comments are welcomed
    Hmm. I don't see foam as a stiffener personally.
    how much weight will this add?
    Interesting, so is this like that expanding yellow foam stuff? I guess enough of it could be stiffening if you squirt it inside of every hole
    Yup ! theres a few 240 guys that have done it. or seam welding can be done but thats wayyy more work
    Oh wait, James just "lieked" my post..... I just realized how dirty that sounded
    FriskyDingo Active Member
    Canada
    2000 Corolla CE
    I think seam welding would be better, everyone should learn how to weld anyways its always handy.
    I kinda know how to weld but only on a mig welder. i want to learn tig welding
    Lmaoo I saw that.
    Canada
    2000 Corolla CE
    A mig is all youd need for this, tig is for making sexy welds which these dont need to be.
    There have been many times I wish I knew how :deskflip:
    Rockandrolla New Member
    Foam? The rigitdity would be better from welds
